Civil Engineering Association Software Software Product Non Engineering Software Foxit PhantomPDF Business v10.1.3.37598
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,128
Likes: 30,986 in 4,091 posts
Given Likes: 612
03-23-2021, 08:18 AM
Complete Business Ready PDF solution that expands upon PhantomPDF Standard by offering advanced editing, shared review initiation, higher security, additional file compression, PDF A/E/X creation, and bates numbering.
FEATURES :-
Edit Text
Edit text in a paragraph without worrying about layout - text will automatically reflow as you edit. After editing, spell check the document.
Advanced Text Editing
Advanced editing capabilities for PDF documents with more complex layout. Link, join, or split text blocks to connect text for more powerful editing. Move and resize text blocks to change to a more compelling layout.
Advanced Object Editing
Edit images, objects, and object shading. Change text to shape. Change page layout properties, add shading to objects, convert text to path, merge/split text, and edit .ai files.
Modify And Format Text
Edit the font of PDF text by changing type, style, size, color, and effect. Align text left, center, or right, while choosing from multiple line spacing options.
Professionalize Documents
Customize the way your PDF looks by adding or modifying stamps, watermarks, headers, footers, and backgrounds to generate professional looking PDFs.
Insert Objects, Images, & Videos
Embed images and videos in your PDF and make it more interactive. Align objects on the left, middle, or center. Distribute objects horizontally or vertically. Rotate, flip, or shear objects.
Create Industry-Standard PDF
Create PDF's from hundreds of the most common file types that are 100% compatible with other PDF products. Reduce file size before you distribute or archive to save transfer time and disk space.
Export PDF To Word & Other Formats
Easily share PDF content by exporting to MS Word, PowerPoint and Excel, RTF, HTML, XML, text, and image formats.
Create PDF from Microsoft Office, Outlook, and Visio
Create PDF with integrated, fully functional Word, PowerPoint, Excel, Outlook, and Visio add-ins.
PDF Form Generation
Develop PDF forms quickly and easily with automated form field recognition and designer assistant. Create professional looking forms with push and radio buttons; check, combo, and list boxes; and text and signature fields.
[Image: 10719830262034358208.png]
[-] The following 11 users Like BennyP's post:11 users Like BennyP's post
  • Aviator, Dell_Brett, mowafi3m, rami1976, kowheng, zrilek, chenamoy, oanm2000, erbalaji, strengbas, bao2004
  Trimble Business Center Shatter 1 4,609 08-31-2022, 08:29 AM
Last Post: alireza55
  MindGenius Business v6.0.2 rami1976 0 4,040 12-03-2015, 03:42 AM
  Foxit Phantom 2.1.0.0731 clerigo 0 3,660 09-02-2010, 02:43 AM
Last Post: clerigo
  Foxit Reader Pro v4.0.0.0619 cordoba123 0 4,694 07-11-2010, 04:36 PM
Last Post: cordoba123
