Civil Engineering Association eBooks Journals, Papers and Presentations Capacity Demand Diagram Methods Based on Inelastic Design Spectrum
Away  preceptor
Senior Member
Banned
User ID: 8148
Threads: 119
Likes: 1,499 in 170 posts
Given Likes: 44
Points:13,780 EP
10-31-2009, 10:37 AM (This post was last modified: 10-31-2009, 10:47 AM by Dell_Brett.)
[Image: ncb16lul1pbbl1uqx2cp.jpg]
An improved capacity-demand-diagram method that uses the well-known constant-ductility design spectrum for the demand diagram is developed and illustrated by examples. This method estimates the deformation of inelastic SDF systems consistent with the selected inelastic design spectrum, while retaining the attraction of graphical implementation of the ATC-40 Nonlinear Static Procedure. One version of the improved method is graphically similar to ATC-40 Procedure A whereas the second version is graphically similar to ATC-40 Procedure B. However, the improved procedures differ from ATC-40 procedures in one important sense. The demand diagram used is different: the constant-ductility demand diagram for inelastic systems in the improved procedure versus the elastic demand diagram in ATC-40 for equivalent linear systems. The improved method can be conveniently implemented numerically if its graphical features are not important to the user. Such a procedure, based on equations relating the yield strength reduction factor, Ry, and ductility factor, μ, for different period, Tn, ranges, has been presented, and illustrated by examples using three different Ry-μ-Tn relations...
(POST EDITED BY MODERATOR)
.pdf   chopra.pdf (Size: 891.27 KB / Downloads: 211)
[-] The following 23 users Like preceptor's post:23 users Like preceptor's post
  • Dell_Brett, Dell_Brett, kowheng, kowheng, ruaumoko, ruaumoko, DamirDz, DamirDz, robertsas, robertsas, essam2109, essam2109, Ultra Zone, Ultra Zone, jcoronellr, subin91, baikur, pezhmankhan, cmorpar, zrilek, soringer, mad_world, zainseiya
  Philosopy and Application of Capacity Design Sumatra 1 4,137 04-10-2015, 01:21 PM
Last Post: monter
  Seismic Drift Demand and Capacity of Non-seismically Designed Concrete Buildings in H TAFATNEB 0 3,007 04-26-2014, 05:09 PM
  CAPACITY SPECTRUM METHOD BASED ON INELASTIC DEMAND SPECTRA TAFATNEB 0 3,165 12-13-2013, 10:10 PM
  Performance Based Methods for Service Life Prediction ir_71 1 4,622 08-22-2013, 09:22 AM
Last Post: ssobhan
  Displacement-Based Design Methods: Limitations & Performances Sumatra 0 3,518 10-06-2011, 01:21 PM
Last Post: Sumatra
  CAPACITY SPECTRUM METHOD Veggeta 1 5,937 01-16-2011, 06:14 AM
  Equivalent Static vs. Response Spectrum A Comparison of Two Methods Veggeta 0 4,013 11-24-2010, 05:13 AM
Last Post: Veggeta
