Civil Engineering Association eBooks Structural Books Steel Benchmark cases for advanced design of structural steel connection
 melekeen
User ID: 24116
Threads: 12
Likes: 614 in 42 posts
Given Likes: 1353
Points:3,131 EP
01-24-2018, 12:59 PM (This post was last modified: 01-24-2018, 02:37 PM by lisine. Edit Reason: Removed "-" from ISBN )
Author(s)/Editor(s): Frantisek Wald et al. | Size: 21 MB | Format: PDF | Quality: Scanner | Year: 2016 | pages: 189 | ISBN: 9788001058268
[Image: 91392717707539966262.png]
The CBFEM (component-based finite element model) is a new method to analyze and design connections of steel structures. The design focused CM (component model) is compared to FEM (finite elements models). The publication introduces Benchmark Cases for Validation and Verification procedures of structural steel joints. The hierarchy of the System response quantity is prepared for welded and bolted connections as well as for column bases. Each Benchmark Case starts with the task description and includes results of prediction by the analytical model according to EN 1993-1-5, references to experiments, validated the model and numerical experiments, results of prediction by design Finite Element Analyses described in terms of global behaviour and verification of resistance. At the end of the publication, the reader may check his calculation on Benchmark cases prepared for the particular joint. Finite Element Analyses is a current step in the design of steel connections, which allows predicting the generally loaded joints with a complex geometry with the same efficiency and accuracy as the traditionally designed connections based on the best engineering practice. Implementation of the FEA models for the structural steel detailing creates the qualitative step as we may see in other areas of engineering.
[-] The following 28 users Like melekeen's post:28 users Like melekeen's post
  • promo8, blaze, civilphongvan, monter, aslam, sabooryan, Aviator, zrilek, Trishu999, Songoku, PinkPant, febo927, mgdario, apocalipse, milova, caifan, jcbv, tomtumx, Dell_Brett, cace-01, simanta, Ivan_1980, karthikeyans3d, oanm2000, ruaumoko, rendel_©, kowheng, CAMSECT
Threads: 733
Likes: 8,131 in 1,328 posts
Points:98,771 EP
06-22-2024, 04:05 AM
Author(s)/Editor(s): Frantisek Wald et al. | Size: 17.41 MB| Format: PDF| Quality: Scanner| Year: 2016 | ISBN: 9788001058268
  • zrilek, PinkPant, Dell_Brett
  Australia Steel Institute - Design capacity tables for structural steel leong8929 5 5,341 12-26-2022, 10:41 AM
  Structural Steel Design: A Practice Oriented Approach -- Aghayere, Vigil psa_1987 10 8,327 02-11-2021, 02:20 AM
Last Post: eng donny
  Structural Steel Design: Jack C. McCormac saqib 20 18,838 11-16-2020, 02:28 PM
Last Post: KMABD
  Advanced Steel Design of Structures carolinandra 1 1,837 01-08-2020, 08:58 AM
Last Post: kirankumarklk
  Structural Steel Drafting and Design adshrt 3 2,964 07-20-2018, 12:58 PM
Last Post: febo927
  Applied Structural Steel Design - by Leonard Spiegel usman 3 4,385 06-14-2018, 12:26 PM
Last Post: febo927
  Steel Connection Analysis subin91 1 2,130 03-04-2018, 07:37 AM
Last Post: cace-01
