Visual Integrity pdf2cad 11.0
[Image: 36368270287154885088.jpg]
Use pdf2cad to transform vector PDF files into editable CAD drawings such as DXF and DWG saving hours of redraw time. In just seconds, you’ll extract an accurate drawing which can be easily modified in popular engineering programs such as AutoCAD, TurboCAD and MicroStation. Output formats include DWG, DXF and HPGL pdf2cad is ideal for converting CAD drawings, floor-plans, network diagrams and organization charts. It extracts editable CAD entities, layers, objects and text from any computer-generated PDF file while images from scanned PDF files are placed on a non-editable tracing layer.
Features:
Convert PDF files into standard CAD interchange formats, DWG, DXF and HPGL
Convert one file or multiple files using the built in batch mode
Convert all pages or specify a page range
Intelligent object recognition
Combines characters to form editable words and lines of text
Cropping
Add white space to page
Rotate output by any degree
Option to ignore text, images or paths during conversion
Map fonts for high fidelity file match
Scale page to match original dimensions of file
Specify minimum line width
Separates layers in CAD drawing based on color or other definitions
Dashed/dotted lines as segments
Saves all images as referenced file in DXF format
Command-line version and Windows DLL available for developers
Expanded support for non-standard fonts
Option to remove or outline hatches/fills
Improved reporting on errors and warnings
Streamlined interface for faster and easier conversions
OS : Windows XP/Vista/7/8/10
Language : English
[-] The following 10 users say Thank You to TAFATNEB for this post:
  • slowet, cace-01, bridgeengineer, oanm2000, PinkPant, mgdario, geomahesh, Dell_Brett, BLESSED DOVE, erbalaji
