WaterGEMS CONNECT Edition 10.00.00.49
[Image: 06901106718129709273.jpg]
[Image: 76452150008494840016.jpg]
entley Systems Inc., the leading company dedicated to providing comprehensive software solutions for sustaining infrastructure, has released the 10.00.00.49 version WaterGEMS CONNECT Edition is a hydraulic modeling application for water distribution systems with advanced interoperability, geospatial model building, optimization, and asset management tools.
WaterGEMS provides you with a comprehensive yet easy-to-use decision-support tool for water distribution networks. The software helps improve your knowledge of how infrastructure behaves as a system, how it reacts to operational strategies, and how it should grow as population and demands increase.
From fire flow and water quality simulations, to criticality and energy cost analysis, WaterGEMS has everything you need in a flexible multi-platform environment.
WaterGEMS provides numerous software tools for:
- Intelligent planning for system reliability: The capability of the water network to adequately serve its customers must be evaluated whenever system growth is anticipated. With WaterGEMS, effectively identify potential problem areas, accommodate service area growth, and plan capital improvements.
- Optimized operations for system efficiency: Realistically modeling the operation of complex water systems can be difficult. With WaterGEMS, model pump accurately, optimize pumping strategies, and plan shutdowns and routine operations to minimize disruption.
- Reliable asset renewal decision support for system sustainability: When it comes time to renew or replace your water infrastructure, the amount of asset-related information you must consider can be overwhelming. WaterGEMS tools such as Pipe Renewal Planner makes the task much easier by analyzing and comparing a wide range of variables to prioritize renewal decisions.
[Image: comments.png]
[-] The following 8 users say Thank You to TAFATNEB for this post:
  • PinkPant, blaze, emmi, Andrew seah, Dell_Brett, oanm2000, cvidalv, mgdario
WaterCAD CONNECT Edition 10.00.00.50
[Image: 52904932726918812197.jpg]
[Image: 32627829584995612968.jpg]
Bentley Systems Inc., the leading company dedicated to providing comprehensive software solutions for sustaining infrastructure, has released the 10.00.00.50 version WaterCAD CONNECT Edition is an easy-to-use hydraulic and water quality modeling application for water distribution systems. Utilities, municipalities, and engineering fi rms trust WaterCAD as a reliable, resourcesaving, decision-support tool for their water infrastructure.
Utilities and engineering firms around the world trust WaterCAD as a reliable decision-support tool for their infrastructure. Design new water systems and manage existing water networks effectively to reduce disruption risks and energy use. WaterCAD’s ease-of-use helps you successfully plan, design, and operate water distribution systems:
- Increase capacity to adequate service levels.
- Supply clean potable water without interruption.
- Deliver high quality designs cost effectively.
WaterCAD helps you improve design productivity, with:
- Streamlined model building: Leverage and import virtually any external data format to jumpstart the model accurately, easily allocate water demands, and automate terrain extraction and node allocation.
- Organized assessment of alternatives: Assess and compare an unlimited number of physical, design, water demand, network topology, and operational scenarios.
- CAD interoperability: Model in a familiar platform, leveraging CAD tools and shortcuts when using WaterCAD from within MicroStation or AutoCAD. You can also choose to use WaterCAD as a stand-alone application, for additional flexibility.
What's New in WaterCAD CONNECT?
The WaterCAD CONNECT Edition provides a unified, common environment that advances productivity, team collaboration, and project performance. Key new capabilities of the CONNECT Edition releases allow users to:
- Access tools quickly through a modernized ribbon-based user interface with built-in search to find commands more easily, consistent with MicroStation CONNECT Edition and Microsoft products that many users are already familiar with.
- Create and manage customized reports that automatically combine graphs, data tables, color-coded and annotated plan views, and more into a single report.
- Run historical simulations using actual operation of pump and valve controls based on SCADA system records.
- Additional capability in SCADAConnect Simulator.
- Model turbines for energy and revenue generation.
- Include service laterals, for automatic customer load assignment during hydraulic analysis.
- Collaborate on water system design and operation as a team using Bentley CONNECT Cloud Services.
- Create AVI movies of model animations to share with others.
WaterCAD is a subset of WaterGEMS. Use WaterGEMS to also run your model from within ArcGIS and for optimization modules (calibration, design, pump scheduling, pipe assessment, SCADA integration, and network simplification).
[-] The following 2 users say Thank You to TAFATNEB for this post:
  • mgdario, emmi
Bentley STAAD.Pro CONNECT Edition V22 (22.00.00.015)+RCDC+Building Planner kirankumarklk 0 578 01-17-2019, 10:04 AM
Last Post: kirankumarklk
RAM Structural System CONNECT Edition V15 Update 11 er.shyams 0 802 10-16-2018, 11:00 AM
Last Post: er.shyams
STAAD.Pro CONNECT Edition Update 3 (21.03.00.146) RajaK 0 1,080 10-08-2018, 03:12 PM
Last Post: RajaK
STAAD.Pro CONNECT Edition Update 2 (21.00.02.44) kirankumarklk 1 1,147 06-27-2018, 10:48 AM
STAAD Foundation Advanced CONNECT Edition 08.04.00.21 kirankumarklk 1 910 06-27-2018, 09:46 AM
