WaterCAD CONNECT Edition 10.00.00.49
[Image: 21263747704938683890.jpg]
Bentley Systems Inc., the leading company dedicated to providing comprehensive software solutions for sustaining infrastructure, has released the 10.00.00.40 version WaterCAD CONNECT Edition is an easy-to-use hydraulic and water quality modeling application for water distribution systems. Utilities, municipalities, and engineering fi rms trust WaterCAD as a reliable, resourcesaving, decision-support tool for their water infrastructure.
Utilities and engineering firms around the world trust WaterCAD as a reliable decision-support tool for their infrastructure. Design new water systems and manage existing water networks effectively to reduce disruption risks and energy use. WaterCAD’s ease-of-use helps you successfully plan, design, and operate water distribution systems:
- Increase capacity to adequate service levels.
- Supply clean potable water without interruption.
- Deliver high quality designs cost effectively.
WaterCAD helps you improve design productivity, with:
- Streamlined model building: Leverage and import virtually any external data format to jumpstart the model accurately, easily allocate water demands, and automate terrain extraction and node allocation.
- Organized assessment of alternatives: Assess and compare an unlimited number of physical, design, water demand, network topology, and operational scenarios.
- CAD interoperability: Model in a familiar platform, leveraging CAD tools and shortcuts when using WaterCAD from within MicroStation or AutoCAD. You can also choose to use WaterCAD as a stand-alone application, for additional flexibility.
WaterCAD is a subset of WaterGEMS. Use WaterGEMS to also run your model from within ArcGIS and for optimization modules (calibration, design, pump scheduling, pipe assessment, SCADA integration, and network simplification).
[-] The following 6 users say Thank You to TAFATNEB for this post:
  • Dell_Brett, thanzawtun, blaze, Andrew seah, PinkPant, oanm2000
please add new links... because the links are down.. Thanks in advance...
[Image: 36052490208043156916.jpg]
[Image: homepage.png]
[Image: comments.png]
[-] The following 3 users say Thank You to emmi for this post:
  • mgdario, oanm2000, Dell_Brett
Bentley STAAD.Pro CONNECT Edition V22 (22.00.00.015)+RCDC+Building Planner kirankumarklk 0 577 01-17-2019, 10:04 AM
Last Post: kirankumarklk
RAM Structural System CONNECT Edition V15 Update 11 er.shyams 0 801 10-16-2018, 11:00 AM
Last Post: er.shyams
STAAD.Pro CONNECT Edition Update 3 (21.03.00.146) RajaK 0 1,080 10-08-2018, 03:12 PM
Last Post: RajaK
STAAD.Pro CONNECT Edition Update 2 (21.00.02.44) kirankumarklk 1 1,147 06-27-2018, 10:48 AM
STAAD Foundation Advanced CONNECT Edition 08.04.00.21 kirankumarklk 1 910 06-27-2018, 09:46 AM
