Civil Engineering Association eBooks Codes, Manual & Handbook Non-English written codes VENEZUELA - LRFD steel design code.
 anfaga
structural engineer
User ID: 12412
Threads: 39
Likes: 606 in 50 posts
Given Likes: 279
Points:4,924 EP
11-30-2015, 11:37 AM
Author(s)/Editor(s): COVENIN | Size: 8,73 MB | Format: PDF | Quality: Unspecified | Publisher: Fondonorma | Year: 1998 | pages: 571
[Image: 18826263573647038875.jpg]
[Image: 64508471517584236032.jpg]
This Standard provides the criteria and minimum requirements for the design, manufacture, assembly, construction, inspection and maintenance of steel structures and steel composite structures - concrete buildings, as well as that of its members, components, joints and connections, which are planned or implemented in the country, and be applied in conjunction with the Venezuelan Standards and COVENIN -MINDUR. This standard applies to both new buildings and the evaluation, adaptation, rehabilitation, strengthening or repair of existing buildings that meet the requirements of Venezuelan COVENIN - Building Seismic MINDUR 1756-1998. Temporary or interim work must also comply with the provisions of this standard.
Excluding the domain of application of this Standard: hollow sections, cold formed profiles and open web joists (joists), which are governed by specific rules. See transitional provisions. The term structural steel used in this Standard refers to any member or element described in the contract documents as such and / or the need for strength and stability of the structure. These members and structural steel elements are listed in general terms in COVENIN - Standardized MINDUR 1755 Code for the Construction and Steel Structures practices.
The notation used in this standard essentially corresponds to that contained in the Standards of the American Institute of Steel Construction, AISC, especially AISC-LRFD 1993 standard. The system corresponds to MKS units: meter (m), Kilogram force (kgf), Second (s).
[-] The following 4 users Like anfaga's post:4 users Like anfaga's post
  • bridgeengineer, oanm2000, jcbv, Dell_Brett
  VENEZUELA - Seismic design of industrial installations. anfaga 0 3,188 01-12-2016, 01:00 PM
Last Post: anfaga
  VENEZUELA - Seismic design of metallic tanks. anfaga 0 3,651 01-05-2016, 03:32 PM
Last Post: anfaga
  VENEZUELA - Design and construction of structural concrete code. anfaga 0 3,211 11-29-2015, 09:59 PM
Last Post: anfaga
  VENEZUELA - Criteria and minimum action code. anfaga 0 2,854 11-26-2015, 12:54 PM
Last Post: anfaga
  VENEZUELA - Wind actions on structures code. anfaga 0 2,516 11-26-2015, 12:46 PM
Last Post: anfaga
  VENEZUELA - Seismic code. anfaga 0 3,148 11-21-2015, 08:32 PM
Last Post: anfaga
  OFFSHORE STANDARD DNV-OS-C105 STRUCTURAL DESIGN OF TLPS (LRFD METHOD) ir_71 0 3,961 06-17-2011, 01:27 PM
