Civil Engineering Association eBooks Structural Books Analysis & Design Static and Dynamic Analyses of Plates and Shells
 amindoxiti
User ID: 86739
Threads: 203
Likes: 8,341 in 584 posts
Given Likes: 2616
Points:35,180 EP
09-26-2014, 05:45 AM
Author: Hou-Cheng Huang | Size: 8 MB | Format: PDF | Quality: Original preprint | Publisher: Springer | Year: 2013(reprint of the original 1st ed. 1989) | pages: 202 | ISBN: 1447116712 ISBN13: 9781447116714
[Image: 89388168854296177003.jpg]
Over the past decade or so much has been written on the various attempts to produce efficient, accurate and reliable Mindlin plate finite elements. In the late sixties, a degenerated, Mindlin-type, curved shell element was developed and subsequently many improvements in such elements have been made. Reliability and efficiency in use has always been a major objective. Degenerated shell elements have enjoyed widespread popularity despite certain potential defects, including shear and membrane lock­ ing behaviour and spurious mechanisms. After introducing the basic foundations of Mindlin-type elements, this book describes these defects and also gives the reasons for their occurrence. Furthermore, the author proposes an approach to overcome these defects. A series of linear benchmark tests are proposed to illustrate the performance of the assumed strain element formulations. The formula­ tions and applications for material non-linearity are also presented. Both isotropic and anisotropic material models are included together with the results for both static and transient dynamic analyses. Two associated programs are fully documented and provided on floppy discs with test examples. Source codes for the two associated programs are provided: one is for static analysis and the other for dynamic analysis, and the programs can be compiled and run on either a mini or mainframe coniputer via a terminal. The author hopes that this book may provide further impetus in the important research area of plate and shell element technology.
[-] The following 26 users Like amindoxiti's post:26 users Like amindoxiti's post
  • jfjdm, blaze, malc, raja, jcbv, subin91, Dell_Brett, cace-01, ashcivilea, bridgeengineer, slowet, ssobhan, PinkPant, vardan, cristi, draluka, ruaumoko, ting tsai huang, gulilero, mgdario, ykhackhack, Quantumm, zrilek, melekeen, learner20, Mohammad6299
  Static and Dynamic Analysis Of Structures - EDWARD WILSON yakwetu 8 19,832 04-25-2023, 09:08 AM
  Principles of Structural Analysis: Static and Dynamic Loads carolinandra 1 3,484 01-02-2022, 03:32 AM
Last Post: Veggeta
  Nonlinear Mechanics of Shells and Plates in Composite, Soft and Biological Materials amindoxiti 0 3,970 12-26-2018, 12:11 PM
  Theory and Analysis of Elastic Plates and Shells cace-01 3 8,594 07-04-2018, 04:49 AM
Last Post: axcel
  Structural Plasticity: Limit, Shakedown and Dynamic Plastic Analyses of Structures rusty 7 12,807 06-28-2018, 03:13 PM
Last Post: febo927
  Buckling and Postbuckling of Beams, Plates, and Shells amindoxiti 0 3,798 11-04-2017, 06:34 PM
  Buckling of Bars, Plates, and Shells ssobhan 4 9,708 10-17-2017, 08:16 PM
