Civil Engineering Association eBooks Structural Books Analysis & Design Dynamic Stability of Suddenly Loaded Structures
 amindoxiti
User ID: 86739
Threads: 203
Likes: 8,341 in 584 posts
Given Likes: 2617
09-16-2014, 12:45 PM
Author: George J. Simitses | Size: 11 MB | Format: PDF | Quality: Unspecified | Publisher: Springer | Year: 1990 | pages: 290 | ISBN: 1461279321 ISBN13: 9781461279327
[Image: 86288706596688121758.jpg]
Dynamic instability or dynamic buckling as applied to structures is a term that has been used to describe many classes of problems and many physical phenomena. It is not surprising, then, that the term finds several uses and interpretations among structural mechanicians. Problems of parametric resonance, follower-force, whirling of rotating shafts, fluid-solid interaction, general response of structures to dynamic loads, and several others are all classified under dynamic instability. Many analytical and experimental studies of such problems can be found in several books as either specialized topics or the main theme. Two such classes, parametric resonance and stability of nonconservative systems under static loads (follower-force problems), form the main theme of two books by V. V. Bolotin, which have been translated from Russian. Moreover, treatment of aero elastic instabilities can be found in several textbooks. Finally, analytical and experimental studies of structural elements and systems subjected to intense loads (of very short duration) are the focus of the recent monograph by Lindberg and Florence. The first chapter attempts to classify the various "dynamic instability" phenomena by taking into consideration the nature of the cause, the character of the response, and the history of the problem. Moreover, the various concepts and methodologies as developed and used by the various investigators for estimating critical conditions for suddenly loaded elastic systems are fully described. Chapter 2 demonstrates the concepts and criteria for dynamic stability through simple mechanical models with one and two degrees of freedom.
[-] The following 22 users Like amindoxiti's post:22 users Like amindoxiti's post
  • cace-01, PinkPant, harsono, jcbv, Mohammad6299, vardan, blaze, Dell_Brett, dinu69in, zrilek, malc, gulilero, ykhackhack, ssobhan, bridgeengineer, lisine, bigone, englandboy, slowet, cristi, toa011, Trishu999
  Static and Dynamic Analysis Of Structures - EDWARD WILSON yakwetu 8 20,172 04-25-2023, 09:08 AM
  Stability of Elastic Structures amindoxiti 2 6,416 07-04-2018, 04:47 AM
Last Post: axcel
  Structural Plasticity: Limit, Shakedown and Dynamic Plastic Analyses of Structures rusty 7 13,078 06-28-2018, 03:13 PM
Last Post: febo927
  Stability of Structures by Finite Element Methods, amindoxiti 2 7,182 04-21-2016, 10:52 AM
Last Post: bridgeengineer
  Theory of Arched Structures: Strength, Stability, Vibration pezhmankhan 6 10,746 08-18-2015, 05:53 AM
Last Post: emmi
  Structures Subjected to Repeated Loading: Stability and strength babak 2 6,676 12-26-2014, 07:58 PM
  Stability of Structures: Elastic, Inelastic, Fracture and Damage Theories Flexi 14 21,078 12-23-2014, 07:00 AM
