The Extension Of The N2 Method To Asymmetric Buildings
Author: Peter Fajfar, Damjan Marušić and Iztok Peruš | Size: 358 KB | Format: PDF | Quality: Unspecified | Year: 2005 | pages: 17
The paper deals with the extension of the N2 method to asymmetric building structures, represented by a 3D structural model. The results of recent parametric studies suggest that in the majority of cases an upper limit for torsional effects can
be estimated by a linear dynamic (spectral) analysis. Based on this observation, it is proposed that the results obtained by pushover analysis of a 3D structural model be combined with the results of a linear dynamic (spectral) analysis. The former results control the target displacements and the distribution of deformations along the height of the building, whereas the latter results define the torsional amplifications. In the paper, first the theoretical background of the transformation of a 3D MDOF model to an equivalent SDOF model is given. Then, the proposed extended N2 method is summarized and applied to a test example of an asymmetric three-storey reinforced concrete frame (“SPEAR”) building. The results are compared with results of nonlinear dynamic time-history
analyses.
[-] The following 10 users say Thank You to TAFATNEB for this post:
  • amindoxiti, rezart, cace-01, vardan, zrilek, malc, PinkPant, blaze, slowet, Clouseau
Simple Method for Pushover Curves of Asymmetric Structure with Displacement-Dependent TAFATNEB 0 1,241 04-09-2014, 07:01 PM
THE EXTENSION OF THE N2 METHOD TO ASYMMETRIC BUILDINGS cve_jule 0 1,197 09-09-2011, 08:30 AM
Last Post: cve_jule
Seismic behavior of asymmetric RC wall buildings miquan 1 1,966 12-01-2010, 07:16 PM
Last Post: hich
Seismic behavior of asymmetric RC wall buildings: principles and new deformation-base melkat 0 1,494 11-06-2010, 05:56 PM
Last Post: melkat
