Civil Engineering Association eBooks Journals, Papers and Presentations PREDICTION OF GROUND VIBRATION FROM RAILWAYS
Likes: 9,404 in 1,160 posts
Points:118,565 EP
08-12-2014, 02:16 PM
Size: 3.4 MB | Format: PDF | Quality: Unspecified | Publisher: SP Swedish National Testing and Research Institute Acoustics SP REPORT 2000: 25 Borås 2000 | Year: 2000 | pages: 103
Field measurements were carried out at two sites in southwest Sweden. Three, 3-directional accelerometers were used at three different distances from the middle of the railway track. All the accelerometers were mounted 50cm below the ground surface. Each accelerometer for the three directional accelerometers was mounted to represent one direction, the X direction is perpendicular to the railway track, the Y direction is parallel to the railway track and the Z direction is the vertical direction on the ground. The signal generated due to the passing trains were recorded by Sony Digital Recorder (DAT). Due to the fact that, this DAT has eight input channels and we used three 3-directional accelerometers, which
means nine accelerometers, one channel had to be omitted.
MATLAB was used to analyse the signals. The vibration levels were analysed using time weighting Sand the acceleration values were converted to velocity values. These measurements were carried out on three different types of trains: X2000, intercity, and freight trains.
  • shadabg, chenamoy, gulilero, oanm2000, blaze, malc, zrilek
  Evaluation of parameters affected on the blast induced ground vibration (BIGV) by usi TAFATNEB 0 3,695 08-31-2013, 10:09 PM
  Railways 2012: The First International Conference on Railway Technology raffah 1 4,560 04-23-2012, 02:51 PM
  TTM Ground Anchors, Geotechnical and ground anchor system ir_71 0 4,485 06-24-2011, 06:16 PM
  RECENT ADVANCES IN GROUND ANCHOR AND GROUND REINFORCEMENT TECHNOLOGY giguni 0 4,661 09-27-2010, 02:38 PM
Last Post: giguni
