Civil Engineering Association eBooks Journals, Papers and Presentations Mitigation of earthquake induced vibrations by Tuned Mass Dampers
Likes: 9,406 in 1,160 posts
08-12-2014, 09:07 AM
Author: Alexander Tributsch , Christoph Adam , Thomas Furtmüller | Size: 2.4 MB | Format: PDF | Quality: Unspecified | Publisher: Proceedings of the 8th International Conference on Structural Dynamics, EURODYN 2011 Leuven, Belgium, 4-6 July 2011 | Year: 2011 | pages: 08
[Image: 99996281538560312829.jpg]
This paper addresses the assessment of the performance of Tuned Mass Dampers (TMDs) to mitigate seismic induced structural vibrations. Two different sets of recorded ground motions are employed: the first set contains far-field records, the second one near-field records with strong pulse characteristics. The evaluation of the TMD efficiency and of its
optimal parameters is based on reduction coefficients, which are derived from the ratio of the structural response with and without attached TMD. These response quantities are evaluated statistically, and the difference between the outcomes for both ground motion sets is quantified. Numerous combinations of parameters are consulted to predict the effect of detuning from optimal TMD parameters. It is verified that a TMD damping coefficient larger than the optimal one reduces the peak deflection of the TMD spring significantly, while the response reduction of the main structure remains almost unaffected.
  • vardan, blaze, ssobhan, PinkPant, malc, zrilek
  Earthquake-Induced Collapse Simulation of a Super-Tall Mega-Braced Frame-Core Tube Bu TAFATNEB 1 8,036 10-30-2020, 08:45 AM
Last Post: gbn1980
  Non-linear viscoelastic modelling of earthquake-induced structural pounding TAFATNEB 0 3,372 04-23-2014, 03:37 PM
  ENERGY DISSIPATION OF TUNED MASS DAMPERS DURING EARTHQUAKE EXCITATIONS asim99 0 3,711 11-28-2012, 10:30 PM
Last Post: asim99
  Lightweight Footbridges for Human Induced Vibrations datagap 3 7,113 10-13-2012, 04:30 PM
Last Post: gulilero
  Journal of Vibration and Control - Designing optimal multiple tuned mass dampers lisine 0 4,615 03-06-2012, 09:24 AM
  Earthquake Mitigation Seismic Retrofit of Buildings junaid 0 4,043 10-02-2011, 03:29 AM
Last Post: junaid
  A Method of Estimating the Parameters of Tuned Mass Dampers for Seismic Applications DamirDz 0 4,137 08-24-2011, 06:57 PM
Last Post: DamirDz
