Civil Engineering Association eBooks Journals, Papers and Presentations PPT NASCC The Steel Conference
 RyanRS
Indonesia
User ID: 32427
Threads: 188
Likes: 4,683 in 228 posts
Given Likes: 765
08-09-2014, 02:06 PM
NASCC The Steel Conference PowerPoint
Size: - MB | Format: PDF | Quality: Original preprint | Publisher: AISC
[Image: 77915823576097014108.jpg]
Selected NASCC The Steel Conference PowerPoint
- Introduction to Seismic Design (73 slides)
- AISC Seismic Moment Frame Design (208 slides)
- AISC 358 Prequalified Connection for Seismic Applications (99 slides)
- Changes in the 2010 Seismic Provisions for Structural Steel Buildings (83 slides)
- Performance-Based Seismic Design Today and Tomorrow (83)
- The AISC Seismic Design Provisions Past, Present and Future (71 slides)
___________________________________________________________________________________________
- A First Look at the 14th Edition Manual & 2010 Specification (119)
- What's on the Horizon for AISC Standards in 2010 (125 slides)
- An Introduction to Earthquake Engineering and Seismic Codes (Part 1 Ductility) (88 slides)
- Stability Under Dynamic (Earthquake) Loads (86 slides)
- 50 Tips for Designing Constructable Steel Buildings (68 slides)
- Tips on Connection Design (176 slides)
- A Standards Approach to Connection Design (135 slides)
- A Guide to The Preliminary Design Process (52 slides)
- Design of Horizontal Diaphragms and Collector Beams for Seismic Lateral Load Resisting Systems (52 slides)
- Mechanism Analysis in the 2010 Seismic Provisions (58 slides)
- Steel Deck Diaphragm Design From Understanding Behavior to Efficient Field Installation (68 slides)
- A Special Report from New Zealand (102 slides)
- Welding Code Updates What's New in 2010 (237 slides)
- Seismic Filler Metals (45 slides)
- Better Base Plates by Design (83 slides)
- HSS Applications, Use, and Limitations of Chapter K of AISC 360-05 (75 slides)
- Behavior and Design of Composite Column Systems Recent Research and New Provisions (86 slides)
- Behavior and Design of Stability Bracing (105 slides)
- Stability and Design of Plate Girders (101 slides)
____________________________________________________________________________________________
- A Story about the Principles of Constructability The John Hancock Building (52 slides)
- Uniform Force Method (53 slides)
- Unleash the Power of Mathcad (33 slides)
- Simplified Finite Element Method for Predicting Low Frequency Floor Vibration due to Walking (57 slides)
- Implementing BIM in Your Structural Engineering Firm (59 slides)
- Implement a Software Error Reduction Plan (SERP) (54 slides)
- AISC 2010 Specification Appendix 4 (Part 1) Structural Design for Fire Conditions (79 slides)
- AISC 2010 Specification Appendix 4 (Part 2) Structural Design for Fire Conditions (38 slides)
- Stability and Design of Beams (102 slides)
- Floor Vibrations Beyond Design Guide 11 (93 slides)
- Code Complexity (60 slides)
- So You Want to be A Structural Engineer (59 slides)
- Exposed Column Base Plates What Three Years of Testing Taught Us (71 slides)
- Quality Control and Assurance Are You Ready for Chapter N (93 slides)
- To Camber or Not to Camber (57 slides)
- MythBusters The Connection Edition (62 slides)
- Cellular and Corrugated Web Beams (90 slides)
- Expansion Joints (79 slides)
[-] The following 19 users Like RyanRS's post:19 users Like RyanRS's post
  • PinkPant, Dell_Brett, apocalipse, Mohammad6299, yucapareja, jcbv, Albert, rendel_©, gulilero, spiderthan, cace-01, ASEC, milova, malc, Hengki, ting tsai huang, eng donny, bigone, faros3000
  Proceeding of the Nordic Steel Construction Conference 2009 serra 1 4,710 03-29-2012, 10:00 AM
Last Post: ssobhan
