A Theory of Latticed Plates and Shells: G. I. Pshenichnov
Author: G. I. Pshenichnov | Size: 35 | 4 MB | Format: PDF | Quality: Unspecified | Publisher: World Scientific Publishing Co | Year: 1993 | pages: 309 | ISBN: 9810210493
The book presents a theory of latticed shells constructed on the basis of a continual model and describes its applications. It analyzes the problems of statics, stability, dynamics. A special emphasis is laid on the study of linear problems. However, in some instances the geometrical and physical nonlinearity are also considered. The problems of optimum designing in terms of material consumption is given considerable attention. Some of the findings are generalized and extended to the edged and composite systems. In dealing with specific boundary value problems the author applies, among other methods, a new method of decomposition which he has developed and which helps to obtain simple approximated results characterized by high accuracy and used for calculating the elements in a broad class structures.
35 MB pdf
4 MB djvu
[-] The following 17 users say Thank You to r3be1 for this post:
  • gulilero, zrilek, Mohammad6299, warlord1, amindoxiti, slowet, TAFATNEB, malc, bridgeengineer, Dell_Brett, Jackass, blaze, subin91, PinkPant, cace-01, mgdario, draluka
Dreams are not what you see in sleep. They are the things that do not let you sleep. - A.P.J. Abdul Kalam.
[-] The following 7 users say Thank You to i_kabir for this post:
  • amindoxiti, PinkPant, jfjdm, Mohammad6299, Dell_Brett, cristi, oanm2000
[-] The following 7 users say Thank You to rami1976 for this post:
  • Dell_Brett, bridgeengineer, PinkPant, melekeen, jcbv, cace-01, oanm2000
Nonlinear Mechanics of Shells and Plates in Composite, Soft and Biological Materials amindoxiti 0 540 12-26-2018, 01:11 PM
The Nonlinear Theory of Elastic Shells by Libai & Simmonds aleph177 4 2,943 08-22-2018, 09:46 PM
Last Post: Kurucz
Theory and Analysis of Elastic Plates and Shells cace-01 3 2,559 07-04-2018, 05:49 AM
Last Post: axcel
Elementary Theory of Elastic Plates amindoxiti 2 1,738 05-28-2018, 03:00 PM
Theory of plasticity and limit design of plates amindoxiti 1 2,699 12-22-2017, 10:05 PM
