Civil Engineering Association eBooks Journals, Papers and Presentations SEISMIC ANALYSIS OF RETAINING WALLS WITHIN PLASTICITY FRAMEWORK
04-27-2014, 07:35 AM
Author: T.Kalasin and D. Muir Wood | Size: 310 KB | Format: PDF | Quality: Unspecified | Publisher: The 14 th World Conference on Earthquake Engineering October 12-17, 2008, Beijing, China | Year: 2008 | pages: 11
[Image: 84670067750653684519.png]
Aseismic design of gravity wall still is a more difficult issue. The reason stems from the complexity of the problem which requires skills in soil mechanics, foundation engineering, soil-structure interaction along with knowledge of structure dynamics. Designing seismic gravity retaining structures deals with both kinematic interaction and inertial interaction but almost seismic building code neglected the soil-structure interaction by using the fixes base analysis of the structure. The gravity walls are a slender tall structure
and it was suggested to be taken into account of dynamic soil-structure interaction analysis because such walls often perform badly when subjected to strong earthquake ground motion. Also the permanent displacement should be evaluated when designing the seismic gravity walls so that the need of the most reliable approach to evaluate a wall’s vibration properties is required. In this paper, the alternative development of computed permanent responses was proposed in order to predict permanent responses of the
seismic wall. The proposed model was constructed within the concept of macro-element modelling the soil, foundation and the seismic earth pressures. The constitutive law for modelling soil and foundation were based on two-surface kinematic hardening with associated flow rule. The development of seismic earth pressures was based on the Mononobe-Okabe method (1929) and the elastic–perfectly plastic method (Muir Wood and Kalasin(2004)) which based on the kinematic hardening by updating of a reference position for the wall. A parametric study is presented and The results are compared with published experimental results.
  • rezart, vardan, malc, zrilek
  Seismic earth pressures on retaining structures in cohesionless soils bridgeengineer 0 4,833 04-22-2016, 06:06 AM
Last Post: bridgeengineer
  Seismic earth pressures on retaining structures with cohesive backfills bridgeengineer 0 4,548 04-21-2016, 09:18 PM
  Soil-Structure Interaction of Retaining Walls under Earthquake Loads TAFATNEB 0 5,441 12-26-2014, 10:12 PM
  seismic design of retaining structures TAFATNEB 0 3,596 04-27-2014, 08:09 AM
  A review of design methods for retaining structures under seismic loadings TAFATNEB 0 3,883 04-27-2014, 07:51 AM
  PUSHOVER ANALYSIS FOR PERFORMANCE BASED-SEISMIC DESIGN OF RC FRAMES WITH SHEAR WALLS TAFATNEB 0 4,958 04-11-2014, 09:13 AM
  Seismic strengthening of RC structures with exterior shear walls TAFATNEB 0 3,905 11-24-2013, 12:03 AM
