Civil Engineering Association eBooks Journals, Papers and Presentations Dynamic behavior of masonry structures under pyroclastic flows
Likes: 9,403 in 1,160 posts
Given Likes: 2851
Points:118,565 EP
11-02-2013, 01:06 PM
Author: Junji KIYONO , Robin J.S. SPENCE and Tadayoshi NAKASHIMA | Size: 0.31 MB | Format: PDF | Quality: Unspecified | Publisher: Journal of Natural Disaster Science, Volume 28, Number 2, 2006, pp73-83 | Year: 2006 | pages: 11
[Image: 71618778987440843903.png]
Pyroclastic flow is a dangerous hazard for people and houses so buildings have to provide a measure of protection
to the occupants. In order to improve the structural strength of buildings, we need to know the structural
behavior against the lateral pressure of the flow. In this study, dynamic behavior of unreinforced masonry structures
affected by pyroclastic flows was analyzed using 2-dimensional (2D) Distinct Element Methods (DEM).
DEM is a numerical analysis technique, in which the positions of elements are calculated by systematically solving
equations. The structure is modeled as an assembly of distinct elements connected by virtual springs and dashpots
where elements come into contact. Masonry structures with simple structural elements; walls, floors, a roof,
and furniture were modeled. The strength of mortar was varied to check the effect of pyroclastic flow on the structural
behavior under different conditions. Pressure acting on a wall due to pyroclastic flow was modeled as a simple
time function of which the peak value was varied from 0.1 MPa to 10 MPa. A pressure model of which intensity
changes with height was also treated. Tilting, lateral movement, collapse and swept away within several seconds
are the typical collapse process of a weak masonry structure even when the lateral pressure is 1 KPa. collapse of the masonry structure is controlled by the relation between the overturning moment due to the lateral
pressure and the resistant moments due to gravity and mortar joint strength.
[-] The following 3 users Like TAFATNEB's post:3 users Like TAFATNEB's post
  • blaze, malc, vardan
  Experimental studies of the ultimate behavior of seismically-isolated structures arshiakh 0 3,038 08-13-2014, 03:37 PM
Last Post: arshiakh
  SEISMIC BEHAVIOR OF DAMAGED BUILDINGS: A COMPARISON OF STATIC AND DYNAMIC NONLINEAR A TAFATNEB 0 2,844 08-10-2014, 02:06 PM
  DYNAMIC RESPONSE OF HIGH RISE STRUCTURES UNDER THE INFLUENCE OF DISCRETE STAGGERED SH TAFATNEB 0 3,341 05-30-2014, 01:55 PM
  EARTHQUAKE RESISTANCE OF STRUCTURES AND DYNAMIC RESPONSE USING LARGE FACILITIES EXPER TAFATNEB 0 3,070 04-23-2014, 03:44 PM
  IDENTIFYING CONFIGURATION AND CONNECTION DETAILS OF UNREINFORCED MASONRY STRUCTURES I TAFATNEB 0 2,719 11-02-2013, 11:16 AM
  STRUCTURAL DAMAGE ASSESSMENT OF BUILDING STRUCTURES USING DYNAMIC EXPERIMENTAL DATA asim99 0 3,373 12-31-2012, 02:00 AM
Last Post: asim99
  THE BEHAVIOR OF INVERTED PENDULUM STRUCTURES DURING EARTHQUAKES Ernest0 0 3,686 10-18-2012, 01:07 AM
Last Post: Ernest0
