deskDOC DWG to PDF Professional 4.7.8
Current time: 08-15-2018, 06:29 PM
Author: TAFATNEB
Replies 0
Views 1288
[Image: 94348042690647687350.jpeg]
deskDOC® DWG to PDF Professional is the perfect DWG to PDF converter for business and enterprise — combining the power to convert DWG/DXF/DWF to PDF and GIF/JPG/PNG/TIFF/BMP with an extremely competitive price. NO AutoCAD required, batch conversion supported.
Convert CAD drawings to sharable PDF files
deskDOC® DWG to PDF converts DWG and DXF files to vector PDFs that you can easily share with others - and you don’t need AutoCAD® to use it! CAD versions supported include R2.5/2.6 to R2005/2006/2007/2008 formats.
Choose layers and layouts to convert
Select only specific layouts or layers to convert, and change PDF colors. With version 4 you can use your DWG settings to control page layout in your conversion.
Precisely control your PDF output
Scale your conversion using Extents, Display, or Layout Limits. You can also customize line widths to include in your drawing or suppress the display of lines.
Convert your drawings to image formats - BMP, GIF, PNG, TIF, or JPG
Convert your drawings to image formats - BMP, GIF, PNG, TIF, or JPG. deskDOC® DWG to PDF professional makes your drawings more usable and versatile than ever!
No AutoCAD required, batch conversion supported.
deskDOC® DWG to PDF professional allows you to convert DWG to PDF, DXF to PDF, DWF to PDF directly, NO AutoCAD required, batch conversion supported.
[-] The following 1 user says Thank You to TAFATNEB for this post:
  • 3fan
