Civil Engineering Association eBooks Journals, Papers and Presentations An E cient Seismic Analysis Procedure for Torsionally Coupled Multistory Buildings In
09-14-2013, 10:32 AM
An E cient Seismic Analysis Procedure for Torsionally Coupled Multistory Buildings Including Soil-Structure Interaction
Author: Erkan C ELEB _ I ; A. Necmettin G ¨ UND ¨ UZ | Size: 0.42 MB | Format: PDF | Quality: Unspecified | Publisher: _ Istanbul Technical University, Department of Civil Engineering _ Istanbul-TURKEY | Year: 2004 | pages: 15
[Image: 10387159696618472883.png]
In this paper, a simpli ed methodology of analysis for the seismic response of 3-dimensional irregular
high-rise buildings on a rigid footing resting on the surface of a linear elastic half-space is formulated.
An e cient method using modal decomposition and carried out in the frequency domain by using the
fast Fourier transform to obtain the structural response of torsionally asymmetric buildings, including soilstructure
interaction e ects, is presented. Applying this algorithm, full advantage is taken of classical normal
mode approximation, and the interaction problem is solved easily and e ectively within the framework of
the Fourier-transformed frequency domain analysis for a xed-base structure. The matrix formulation of
this method produces accurate approximation with less computational e ort, in spite of using the frequency
dependent impedance functions.
  • rezart, malc, blaze, vardan, warlord1, gulilero, hatkam, ykhackhack, ruaumoko
  Numerical seismic vulnerability analysis of mid-height steel buildings in Bogotá, Col TAFATNEB 0 3,983 05-09-2014, 10:44 AM
  LOS ANGELES INVENTORY OF NONDUCTILE CONCRETE BUILDINGS FOR ANALYSIS OF SEISMIC COLLAP TAFATNEB 0 3,644 04-18-2014, 05:50 PM
  NON LINEAR SEISMIC ANALYSIS OF ANCIENT BUILDINGS Structural Characterization for Succ TAFATNEB 0 4,158 04-17-2014, 09:22 AM
  P ERFORMANCE OF PUSHOVER PROCEDURE IN EVALUATING THE SEISMIC ADEQUACY OF REINFORCED C TAFATNEB 0 3,857 04-09-2014, 05:55 PM
  Influence of Nonlinear SSI on the Seismic Response of Reinforced Concrete Multistory TAFATNEB 0 4,135 11-23-2013, 02:39 PM
  Effectiveness of modified pushover analysis procedure for the estimation of seismic d TAFATNEB 0 3,883 11-23-2013, 12:26 PM
  A QUASISTATIC ANALYSIS METH OD TO IMPROVE COLLAPSE MECHANISM ANALYSES OF MULTISTORY B TAFATNEB 0 3,946 11-22-2013, 11:15 PM
