Pelikan Software priPrinter Professional v5.6.0.2060 ML
[Image: 45889386510100632148.png]
[Image: 37748211669845422318.png]
priPrinter is a printer driver that allows you to manipulate printer output before it is printed. priPrinter is installed and selected in the same way as other printer drivers. After printing it automatically displays print preview where you can preview your printings, change layout, reposition pages, crop them and many more. After that you print it to the real printer or save your document for later using. With priPrinter you always will be sure how your printings will look. You may measure items on the paper, define margins and pages layout. There is no need to print again and again trying to achieve desired placement.
Features:
• Provides every feature you need to make your print easy and simple.
• Preview your printing in many ways. Explore content of your jobs.
• Print to images. You may save your prints to various image formats.
• Booklet and posters.
• Duplex printing.
• Measurements.
• Print themes
• Loupe tool.
• Margins and gutters. Change margins and gutters with mouse click and drag.
• Crop and Cut. Remove blank space and redundant information.
• Undo/Redo
• Small and fast.
• Save jobs to file.
• Tray control
change log v5.6.0.2060 (13 June 2013 )
• Now priPrinter is able to restore images divided into bands by print application. It should help to avoid white lines in print preview and output images. Related to Adobe Lightroom and other applications.
• Added an ability to revert changes made in print preview pane: printer, duplex mode, ink saving settings. This option is in pane properties dialog.
• priPrinter Server in offline mode is able to display some job information: for instance computer and user name.
• Print in bitmap mode is very much optimized. As result spooler queue/files must be smaller. Important for huge documents printing. Related to ink saving mode, contrast/brightness controls.
• Text in main print button and in few items in print preview pane should be displayed with correct font now - related to Arabic, Persian, Korean and Japan localizations.
• New script functions are added (PRO).
• Improved installer for priPrinter Server. Now it is possible to skip driver installation if compatible driver is installed already (SERVER).
• Minor improvement in patterns rendering.
[-] The following 14 users say Thank You to henrybill for this post:
  • DAVOODTEKLA, usman, milvio, blaze, kostell, oanm2000, cace-01, Rainbow, red_pool61, ssobhan, gulilero, melkat, melekeen, smrutigandh.42
[-] The following 1 user says Thank You to arspi for this post:
  • chenamoy
