Plate-Load Tests of Collapsible Soils
Author: Yakov M. Reznik | Size: 385 KB | Format: PDF | Quality: Unspecified | Publisher: ASCE | Year: 1993 | pages: 8
Plate-load tests are considered the most reliable and informative source of soil-deformation properties required for a successful foundation design. Plate-load test results are influenced by many factors: plate or experimental foundation dimensions/configuration, soil conditions, testing technique, etc. Numerous experiments demonstrated that there is a linear relationship between settlements of plates or foundations and square roots of their areas varying between approximately 0.06 and 25.0 m². Two major soil parameters (deformation modulus and proportionality limit) can be determined utilizing a load-settlement curve developed from field tests. Collapsible soil behavior under foundations depends on the degree of soil-saturation values. This paper presents the results of plate-load tests performed on collapsible soils under in situ and wetted conditions. The results of laboratory and field tests are compared.
a- Follow the Forum Rules.
[-] The following 9 users say Thank You to asim99 for this post:
  • Dell_Brett, Jackass, maxpn3, oanm2000, shadabg, utan, kowheng, mary, jaejeong
