Elastic beams and frames - 2nd Edition
Author: John D. Renton. | Size: 20 MB | Format: PDF | Quality: Unspecified | Publisher: Woodhead Publications | Year: 2002 | pages: 423 | ISBN: 9781898563860
[Image: 74560070355947722109.jpg]
The book approaches the basic theory of structures from a different perspective from standard pedagogy. There is consideration of work and energy concepts as fundamental and the equations of statics derived from them. Likewise, these concepts, together with that of the characteristic response, are used in the derivation of beam theory. Plane sections remaining plane is then seen as a particular result for isotropic, homogeneous, prismatic beams. The general theory may still be used where none of these conditions holds, and can even be applied to trusses. It also corrects errors in the theory of beam shear. Special topics discussed include non-uniform torsion, the exact analysis of shear, anisotropy, advanced energy methods, optimum structures, and regular frames. Software provided in the book includes seven general purpose programs for analysis of plane, space frames with rigid or pinned joints, and uses the augmented Gaussian elimination process and dynamic storage techniques.
a- Follow the Forum Rules.
[-] The following 34 users say Thank You to asim99 for this post:
  • vardan, Dell_Brett, eRw1n, hatkam, jcbv, marion33, ingchio, ibg0203, hernansgz, Jackass, vvvv, lisine, tluc, Sumatra, Rapaig, yutt, cristi, jonny78, kowheng, harsono, malc, subin91, oanm2000, apocalipse, sodapas, Quantumm, gacella, fer962933, zrilek, ykhackhack, TurboXUser, bridgeengineer, K.Lee, giappichel
[-] The following 13 users say Thank You to amindoxiti for this post:
  • bridgeengineer, Dell_Brett, oanm2000, PinkPant, melekeen, eliseo.as, agarciam2, mgdario, jonny78, ykhackhack, promo8, ruaumoko, zrilek
[-] The following 13 users say Thank You to rami1976 for this post:
  • jcbv, amindoxiti, milova, K.Lee, RajaK, caifan, zrilek, blaze, Dell_Brett, sodapas, Trishu999, oanm2000, simanta
Shakedown of Elastic-Plastic Structures - 1st Edition febo927 0 537 06-28-2018, 03:47 PM
Last Post: febo927
Practical Approximate Analysis of Beams and Frames cace-01 1 1,675 09-29-2015, 02:16 PM
Last Post: junaid
Composite Structures of Steel and Concrete: Beams, Slabs, Columns, Frames Flexi 17 13,940 10-21-2014, 08:08 PM
Last Post: r3be1
Analysis and Design of Elastic Beams: Walter D. Pilkey orio777 4 3,988 02-03-2014, 08:17 AM
Last Post: bigone
Design Analysis of Beams, Circular Plates and Cylindrical Tanks on Elastic Foundation jpver 8 8,556 07-19-2013, 08:37 AM
Last Post: arshiakh
