DWGLock - Protecting drawing file
Dear all,
This is the new issued for this thread:
Above is the problem, but below is the software (a kind of solution)
[Image: 82495604937888172953_thumb.jpg]
Why users need this DWG secure software:
Keep others from copying and using part of your drawing
Protect the copyright of the design, especial useful for contractors
Collaboration needs, there is no more concerns of the reviewed drawings has been changed unexpected, while the mark up is still clear and easy to be enclosed.
Home Page:
May someone try to get medicine, and share for us.
Peace,
Jupe
Dwglock
[Image: 52150245306565825334.jpg]
Now you can protect your works with this DWGLock software, the entities in the send out drawings can NOT be copied nor changed. However, recipients can open up the drawing, add lines and markups. Only the drawing owner allows extracting the drawing, if they need to, enclosing the added part with the native drawing. This is ideal solution for the collaboration needs and contractors.
It is a stand-alone application, no AutoCAD required; Supports AutoCAD R2.9 thru 2012 drawings.
Features
Powerful encryption, secure the entities in the drawing, they can not copy nor change it
Recipients can open up protected drawing, and add lines etc to the drawing file.
To drawing owners, please be sure to keep a copy of your design, the encrypted drawing can NOT be unlocked.
Batch encrypt many files or folders in one go.
[-] The following 11 users say Thank You to andersen3 for this post:
  • ykhackhack, knrsa, dquan373, Dell_Brett, eng-hiep, usman, utan, Jackass, ranger, blaze, sructme
Nice try, but it can be beaten.
Use NCOPY.
Moderator Note:
Please, clarify us how NCOPY can protect and keeping open to read AutoCAD dwg file isolate (not burned in a DVD).
Thanks in advance.
Using NCOPY I can copy from a DWGLock protected drawing.
So, DWGLock is not a solution.
[-] The following 1 user says Thank You to w64bit for this post:
  • ykhackhack
There is a Lisp Called 2block with this one you can change the anonymous block to Visible Block then you reinset the same block with explode mode and ready! unprotected dwg
[-] The following 3 users say Thank You to oonan for this post:
  • ykhackhack, Dell_Brett, slowet
