Measured performance of a 26 m deep top-down excavation in downtown Shanghai
Author: Yong Tan and Mingwen Li | Size: 3.9 MB | Format: PDF | Quality: Unspecified | Publisher: anadian Geotechnical Journal | Year: 2011 | pages: 16
Via a long-term comprehensive instrumentation program, the performance of a 26 m deep metro station excavation
constructed by the top-down method in downtown Shanghai was extensively examined. The measured excavation responses
included diaphragm wall deflections, wall settlements, ground settlements, uplifts of interior steel columns, axial
forces of propping struts, groundwater table levels, and settlements of adjacent buildings and utility pipelines. Based on the
analyses of field data, the following major findings were obtained: (i) the concrete struts along with the floor slabs effectively
suppressed later wall movements and consequently reduced the chance that the maximum wall deflections would occur
above the excavation surfaces, (ii) with the progress of excavation to a lower depth, the diaphragm walls underwent a
serrated settlement pattern over time, (iii) no significant post-excavation wall deflection occurred, (iv) the relationship between
the interior column uplifts and the maximum wall deflections can be described by a linear equation, and (v) most system
loads due to soil removal were carried by the concrete struts along with the floor slabs. The struts sustained mainly the
released earth pressures due to the exposure of the adjacent portions of diaphragm walls, and the soil removal distant from
the struts imposed limited effects on the strut axial forces.
a- Follow the Forum Rules.
[-] The following 13 users say Thank You to asim99 for this post:
  • maxpn3, Jackass, Dell_Brett, kowheng, faros3000, subin91, tang1942, eng-hiep, cace-01, shadabg, malc, viet2010, maartenneef
Detection and assessment of damage in 2D structures using measured modal response arshiakh 0 1,123 04-24-2013, 08:03 PM
Last Post: arshiakh
The Deflection of Earth Retaining Diaphragm wall during Deep Excavation shadabg 0 1,394 10-04-2012, 08:30 AM
Last Post: shadabg
A COMPREHENSIVE METHOD FOR DESIGN OF ANCHORED WALL FOR DEEP EXCAVATION shadabg 0 1,244 10-04-2012, 07:50 AM
Last Post: shadabg
The Effect Measured of the Rubber Membrane on the Triaxial Compression Strength tynhanh 0 1,157 04-15-2011, 09:14 AM
Last Post: tynhanh
