Civil Engineering Association eBooks Journals, Papers and Presentations Estimation of mean annual precipitation as affected by elevation using multivariate g
 arshiakh
User ID: 37777
Threads: 100
Likes: 3,224 in 617 posts
Given Likes: 214
04-08-2013, 06:15 PM
Estimation of mean annual precipitation as affected by elevation using multivariate geostatistics
Author: A. Martínez-cob | Size: 1142 KB | Format: PDF | Quality: Unspecified | Publisher: Water Resources Management(Springer) | Year: 1995 | pages: 139-159 | ISBN: --
This paper presents the results of the interpolation of annual precipitation over a regular grid performed in Aragón (Spain). The main objective was the quantification of the improvement in estimation uncertainty by including elevation in the interpolation and by using base 10 logarithms of both annual precipitation and elevation versus the original values.
Long-term annual precipitation (APRE) was available at 182 weather stations. Elevation above sea level (ELEV) was available at those stations and at 1913 additional points over a regular 5 km grid. The spatial variability of APRE, ELEV and their base 10 logarithms (LAPRE and LELEV, respectively), and the spatial correlation between APRE and ELEV, APRE and LELEV, LAPRE and ELEV, and LAPRE and LELEV were described by gaussian direct- and cross-semivariogram models with nugget effects.
Geostatistical interpolation methods, ordinary kriging and cokriging, were used to estimate APRE and LAPRE at the 1913 additional elevation points. Estimates of LAPRE were transformed back to APRE values. Cokriging estimates were in general higher than kriging ones, mainly at points of high elevation. The average percent difference among cokriging and kriging estimates was 9–12%. Cokriging estimates obtained with the different sample data sets were in general terms similar. However, at points of high elevation, cokriging with ELEV as the auxiliary variable seemed to overestimate annual precipitation.
Estimation error standard deviations (EESD) also were computed in each interpolation point. For all points, the EESD obtained using LAPRE values were lower than those obtained using APRE values, being the average percent differences of −38 to −42%. Likewise, for all interpolation points, cokriging EESD were lower than kriging ones. Using LAPRE and LELEV values, the average percent difference among cokriging and kriging EESD was −11.0%, with minimum and maximum percent differences of −6.7 and −35.8%, respectively.
[-] The following 1 user Likes arshiakh's post:1 user Likes arshiakh's post
  • kowheng
  Evaluation of parameters affected on the blast induced ground vibration (BIGV) by usi TAFATNEB 0 3,851 08-31-2013, 10:09 PM
  A comparison of geostatistical procedures for spatial analysis of precipitation in mo arshiakh 0 3,519 04-25-2013, 07:31 PM
Last Post: arshiakh
  Multivariate geostatistical trend detection and network evaluation of space-time acid arshiakh 0 3,214 04-08-2013, 07:33 PM
Last Post: arshiakh
  Temporal-spatial variation and the influence factors of precipitation in Sichuan Prov arshiakh 0 3,447 04-08-2013, 06:12 PM
Last Post: arshiakh
  Multivariate geostatistical approach to space-time data analysis arshiakh 0 3,560 04-08-2013, 05:34 PM
Last Post: arshiakh
  Spatial uncertainty to determine reliable daily precipitation maps asim99 0 3,213 03-27-2013, 06:10 AM
Last Post: asim99
  Spatial interpolation of precipitation in a dense gauge network for monsoon storm eve asim99 0 3,238 03-27-2013, 06:06 AM
Last Post: asim99
