UBC 97, ASCE 7-10, Eurocode 8, NZS 1170.5 Lateral Loads
Current time: 06-18-2018, 12:26 PM
Author: pezhmankhan
Last Post: hmwere
Replies 9
Views 8269
UBC 97, ASCE 7, Eurocode 8, NZS 1170.5 Lateral Loads
[Image: 40340350088474513944.jpg]
Dear Friends,
I write this spreadsheet that calculates Seismic Base Shear and Design Spectra for UBC 97, ASCE 7-10, Eurocode 8, NZS 1170.5-2004.
Please download and check.
I'm waiting for your comments.
[-] The following 23 users say Thank You to araza023 for this post:
  • Dell_Brett, jcbv, Jackass, ranger, bigone, MOSS2000, rendel_©, andtangh, drewpt, mohcivil, amirdana, JAE SUNG LEE, milova, melekeen, salahcivil, zrilek, harsono, ykhackhack, bridgeengineer, blaze, geomahesh, nan54, joker™
I think this file has been expired..
Can you kindly upload this one again or send me an email with this?
boy1457@naver.com
I really want to have a look at this spread sheet.
thank you very much and looking forward to hearing from you soon!
#2 link ok
alternative
concrete solution advocate
[-] The following 13 users say Thank You to concreteok for this post:
  • pezhmankhan, amindoxiti, PinkPant, dizz, serhioSPA, ykhackhack, Dell_Brett, cace-01, ronnie_150, vvvv, cristi, highcivil, zrilek
It always tells "Expired download link".
4shared or Mediafire link please.
Thanks.
[-] The following 1 user says Thank You to dinu69in for this post:
  • subin91
As usual i want to tell you i don't like spamers. 4 share link in post #2 works and the alternative link in uploadboy works too. Your actvity for a long time is only requests and every time even if a link exists you ask someone to upload in your preferd host or declare the link expired. I don't like to download twice a file i don't need only to demonstrate you are lazy and gave other's users to work before you check yourself.
[Image: 04970028467441276361.gif]
[Image: 46734687963681507959.gif]
[Image: 12941873303169360246.gif]
[Image: 46586730431865666273.gif]
  • albani, dinu69in, highcivil, malc, ykhackhack, oanm2000, bigone
[Image: 25796636807676968511.jpg]
[Image: 34474768448302865687.jpg]
Dear pezhmankhan and other Friends,
Mr. Pezhmankhan studied to this important calculation and shared us before.
I studied this excel sheet and tried to develop as below. (Thanks to Mr. Pezhmankhan)
You can download and view from this link:
I hope you will use your analysis calculation. Please feedback calculation fault and other suggestion.
Best Regards.
Strength | Stiffness  | Ductility  |  Stability
[-] The following 20 users say Thank You to highcivil for this post:
  • psk62, ykhackhack, malc, zrilek, ascetic19, ssobhan, agelos100, MOSS2000, PinkPant, pezhmankhan, jcbv, Dell_Brett, cace-01, oanm2000, visu, hmwere, bridgeengineer, blaze, bigone, ruaumoko
locked?
tested and is fine.
[-] The following 6 users say Thank You to concreteok for this post:
  • Dell_Brett, PinkPant, ascetic19, oanm2000, highcivil, bigone
Dear CivilEAns,
I noticed what may seem like an anomaly in the excel sheet made by highcivil.
Say, for example, (Eurocode 8)
1) for maximum surface wave magnitude < 5.5, recommended spectrum type is 2
2) Using spectrum type 2, table 3.3 would be applicable, and not table 3.2 as reported by the excel sheet of highcivil.
Please check and revert.
[-] The following 5 users say Thank You to hmwere for this post:
  • Dell_Brett, oanm2000, temp1366, bigone, highcivil
Loads: Wind Load Calculation -AS-NZ 1170.2.2002 robertsas 2 4,223 11-28-2017, 06:40 PM
Last Post: aslam
Lateral Analysis and Design Loads spreadsheets RedHorse 1 3,197 06-05-2010, 04:18 AM
Last Post: jacky899
