PRINT2CAD 2012 multilingual v:1.0.0.1
Current time: 12-16-2018, 11:34 PM
Author: jonny78
Last Post: ykhackhack
Replies 1
Views 2848
[Image: 50141987958472336798.png]
Print2CAD 2012 is able to convert PDF files into a DWG or DXF file, which can then be imported into any CAD system for editing. Print2CAD 2012 is an autonomous and CAD system-independent program. Print2CAD 2012 also converts DWG/DXF into PDF, TIFF/JPEG into DWG, DWF into DWG/DXF and HPGL into DWG/DXF.
Print2CAD 2012 not only uses conversion and vectorization methods, but also uses OCR (Optical Character Recognition) to reconstruct the content of a PDF or raster file. The program can also recognize the PDF text that has been deconstructed into polyline fields, and/or pixel pictures as full and editable CAD text.
[-] The following 18 users say Thank You to jonny78 for this post:
  • malc, andersen3, cace-01, Dell_Brett, slowet, blaze, chaplin, azas, smrutigandh.42, haze, kvtasp, usman, stosto6666, ykhackhack, SCREAM7890, ranger, steptoe, draluka
@kvtasp
[-] The following 15 users say Thank You to ykhackhack for this post:
  • kvtasp, thanzawtun, andersen3, Dell_Brett, ibmarin, SCREAM7890, chenamoy, nexis35, albani, maijuji, xdesi, Andrew seah, haze, toby62, lednar_ved
