Civil Engineering Association eBooks Structural Books Steel Seismic Design of Buckling-Restrained Braced Frames
 carolinandra
Colombia
User ID: 12281
Threads: 112
Likes: 2,885 in 157 posts
Given Likes: 1333
Points:17,730 EP
02-17-2013, 05:37 PM
Author: Walterio A. López; Rafel Sabelli | Size: 587 KB | Format: PDF | Quality: Unspecified | Publisher: Steel Tips | Year: 2004
Buckling-Restrained Braced Frames (BRBFs) are a new steel seismic-load-resisting system that has found use in the western United States because of its efficiency and its promise of seismic performance far superior to that of conventional braced frames. The system is not yet addressed in the 2005 edition of the AISC Seismic Provisions for Structural Steel Buildings, but nevertheless a set of design provisions has been developed by AISC in conjunction with the Structural Engineer’s Association of California.
This report illustrates the seismic design of buckling-restrained braced frames; they are defined,and the provisions governingtheir design and required testing are explained. A summary ofselected Buckling-Restrained Brace (BRB) testing performed to date is provided. Compliance with design requirements is explained through detailed component design of two typical BRBF configurations and development of testing protocols. A discussion of gusset-plate design and its influence on acceptable frame behavior is provided.
[-] The following 15 users Like carolinandra's post:15 users Like carolinandra's post
  • malc, ting tsai huang, kowheng, pezhmankhan, Jackass, slowet, rendel_©, ibg0203, sodapas, Dell_Brett, cristi, ssobhan, simanta, zrilek, pedzaquino
  buckling restrained braces and applications sabooryan 3 4,135 07-20-2024, 05:28 AM
  Plastic design of low-rise frames malc 0 1,166 10-06-2020, 03:46 AM
Last Post: malc
  Behavior of Long Links in Eccentrically Braced Frames - Engelhardt, M D; Popov, E P andersen3 3 2,553 12-26-2015, 03:55 PM
Last Post: PinkPant
  Analysis, Design and Construction of Braced Barrel Vaults ssobhan 5 3,018 12-19-2014, 08:37 AM
  Moment Resistant Connections of Steel Frames in Seismic Areas: Design and Reliability Grunf 4 4,565 09-07-2014, 09:44 PM
Last Post: apocalipse
  SCI P183: Design of Semi-continuous Braced Frames ir_71 2 1,763 11-15-2012, 04:37 PM
Last Post: ssobhan
  Steel Building Design: Medium Rise Braced Frames ir_71 2 2,567 01-28-2012, 08:52 PM
Last Post: joker™
