Use of Flexible facing for soil nail walls
Current time: 02-19-2018, 04:53 AM
Author: jacs127
Last Post: ssobhan
Replies 2
Views 1169
Author: Several | Size: 3.63 MB | Format: PDF | Quality: Original Preprint | Publisher: Kansas Department of Transportation | Year: Nov, 2011 | pages: 70 | ISBN: none
Soil nail walls are a widely used technology for retaining vertical and nearly vertical cuts in soil. A significant portion of the cost of soil nail wall construction is related to the construction of a reinforced concrete face. The potential for use of a flexible facing design for soil nail walls to replace reinforced concrete facing was evaluated using three-dimensional finite difference modeling and physical testing of a 1.5 meter by 1.5 meter unit cell of a soil nail wall in clay. A steel mesh form of flexible facing was used as a substitute for concrete. The finite difference model predicted large vertical and horizontal deformations for surcharges of approximately 5 psi. In the physical testing, the flexible facing products performed well with regard to strength, but the facing experienced large vertical and horizontal deformations that were consistent with the numerical modeling. Based on these results, it is recommended that use of flexible facing as a substitute for reinforced concrete be limited to non-critical structures where large vertical and horizontal deformations are acceptable.
[Image: 80411040688507873749.png]
[-] The following 5 users say Thank You to jacs127 for this post:
  • blaze, cace-01, techno, shadabg, Dell_Brett
direct link;
“His blue eyes are often bloodshot, and their expression indicates that there is a helpless, baffled soul squirming around inside this doughty fortress.” Prue by Alice Munro, ©1982.
[-] The following 1 user says Thank You to ssobhan for this post:
  • Dell_Brett
another direct link;
[-] The following 4 users say Thank You to ssobhan for this post:
  • Gabemzaman, Jackass, Dell_Brett, Andrew seah
Soil-Structure Interaction of Retaining Walls under Earthquake Loads TAFATNEB 0 1,557 12-26-2014, 11:12 PM
