Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet WS Beam Schedule
WS Beam Schedule
 RANA WASEEM
User ID: 10336
Threads: 119
Likes: 1,021 in 194 posts
Given Likes: 820
01-10-2013, 11:33 AM (This post was last modified: 01-10-2013, 11:34 AM by RANA WASEEM.)
Hello guyz I have developed another major sheet which makes automatic beam schedule.
You can download it here
MAIN FEATURES
WS BEAM SCHEDULE takes data from ETABS, after calculating and evaluating based on your preferences, it generates reinforcement values. In addition to that it suggest reinforcement bars for final CAD beam schedule, doing all that in seconds without any space for errors.
1) Easy and clean input by selecting a single report file from ETABS.
2) Automatically selects nearest bar dia for main bars, stirrups and side bars. Checks for maximum side bars spacing.
3) User can increase reinforcement or specify minimum reinforcement values.
4) Automatically distributes torsion reinforcement for stirrups, side bars, top and bottom steel .
5) Takes maximum of top reinforcement at end sections of continuing beam spans.
6) User can specify to make top and bottom reinforcement same, top left and top right same, can select minimum bar dia of main and secondary bars etc.
7) Different types of outputs, can print Area required vs Area provided comparison with values and percentages, can print suggested bars with reinforcement values or only the suggested bars for CAD.
8) Takes beam properties from ETABS properties not from beam names so eliminating the error of dimension difference between ETABS and beam schedule.
9) Eliminating any possibility of error in reinforcement values as it takes the exact values from ETABS, calculates, evaluate and present a final reinforcement value including torsion reinforcement.
10) Takes less than 10 seconds to build the schedule and saves more than 70% of time taken to make manual beam schedule from ETABS.
WS
[-] The following 21 users Like RANA WASEEM's post:21 users Like RANA WASEEM's post
  • Nilupa, shadabg, aslam, melekeen, isurya, malee, Jackass, blaze, araza023, aMoUr, albani, Dell_Brett, Andrew seah, malc, rafconsult, mowafi3m, bigone, erimajus, manzoor_quadri, uetian19, techno
 RANA WASEEM
User ID: 10336
Threads: 119
Given Likes: 820
01-12-2013, 06:47 AM
Sorry guyz, print preview buttons FOR ENGINEER, FOR CAD and AREA REQUIRED were not working. I have fixed them and added a new point in manual about secondary top middle bars that is note 3-vii in help file. I called this version 1.01
Old version is not available anymore. You can download the new pack from here
WS
[-] The following 12 users Like RANA WASEEM's post:12 users Like RANA WASEEM's post
  • malc, knrsa, aslam, Dell_Brett, shadabg, ykhackhack, manzoor_quadri, araza023, oanm2000, learner20, bigone, tooraj41
Likes: 5,368 in 651 posts
Given Likes: 28539
01-12-2013, 12:28 PM
Dear Rana Waseem:
I received this Message
Quote:'WS BEAM SCHEDULE_Help Menu_ver 1.01.zip' is unavailable. This file was deleted.
 RANA WASEEM
User ID: 10336
Threads: 119
Given Likes: 820
01-12-2013, 12:48 PM
Please download the latest version from
always check this link for any updates..
WS
[-] The following 5 users Like RANA WASEEM's post:5 users Like RANA WASEEM's post
  • bigone, kirankumarklk, ykhackhack, Andrew seah, pedzaquino
 RANA WASEEM
User ID: 10336
Threads: 119
Given Likes: 820
01-12-2013, 02:59 PM
mirror link
WS
[-] The following 8 users Like RANA WASEEM's post:8 users Like RANA WASEEM's post
  • learner20, Dell_Brett, ting tsai huang, oanm2000, shadabg, manzoor_quadri, bigone, eng_ismail
 manzoor_quadri
Saudi Arabia
User ID: 6161
Threads: 39
Likes: 87 in 24 posts
Given Likes: 296
01-17-2013, 09:56 AM
Hello,
I am getting the error as shown in the picture below, when I try to run the sheet, please check.
[Image: 55135379719376230381.jpg]
[-] The following 1 user Likes manzoor_quadri's post:1 user Likes manzoor_quadri's post
  • henchman2010
 RANA WASEEM
User ID: 10336
Threads: 119
Given Likes: 820
01-17-2013, 09:58 AM
Which version you are using? Try to download it again from 4shared or from the blog..latest version is 1.04
WS
[-] The following 1 user Likes RANA WASEEM's post:1 user Likes RANA WASEEM's post
  • oanm2000
 henchman2010
Trinidad and Tobago
User ID: 42405
Threads: 8
Likes: 118 in 19 posts
Given Likes: 15
01-28-2013, 12:06 AM
The spreadsheet is giving a run-time error 424. This seems to be a referencing error. There is a trouble shooting by ms excel site but the procedure is password protected. Dao350.dll or maybe some other file from the dynamic link library.
[-] The following 1 user Likes henchman2010's post:1 user Likes henchman2010's post
  • RANA WASEEM
 RANA WASEEM
User ID: 10336
Threads: 119
Given Likes: 820
08-22-2013, 07:12 AM
Please use the new download link from the website mentioned above in post#4
WS
  • techno
