Lead Rubber Bearing Properties in SAP2000
Current time: 06-19-2018, 08:56 PM
Author: pezhmankhan
Last Post: pezhmankhan
Replies 4
Views 7476
Input your data in INPUT sheet and get outputs in SAP2000 sheet.
I'm waiting for your opinion.
[Image: 87863049178975510893.png]
[Image: 72412140871154035398.png]
Dear pezhmankhan ,
thank you very much for this useful file.
I'm wonder if you could advise where is coming the value of effective damping (0.038) of your example (tab sap2000 : for U2 & U3).
what units should have this property ?
In the input tab I couldn't find this value to see the equation used. Or is a typo and should be 0.088 ? please confirm
really appreciate your comments,
thanks in advance,
Hi,
When you defined effective damping of isolators in SAP2000 (in the horizontal direction, U2 & U3), you should deduct the damping ratio of superstructure from it. Software will automatically add damping ratio of superstructure to effective damping of isolator.
So I put unit to kN-mm and after that I deductive 0.05 from effective damping to consider 5% superstructure damping.
[-] The following 5 users say Thank You to pezhmankhan for this post:
  • ruaumoko, Diquan, Mohammad6299, mowafi3m, bigone
Thanks for your time ! pezhmankhan,
This mean, the unit is a ratio in the input of SAP2000?
Im a bit confuse, when I read in the CSI knowledge base website where explains the unit of effective damping is Force-Second/Length or Force/Velocity”
I misunderstand something?
thank you very much,
[/code]
Yes, You are true.
But in HOLMES spreadsheet they defined effective damping such this. And because this spreadsheet is written by Trver Kelly, I am sure that this way is true.
  • Mohammad6299, ruaumoko, mowafi3m, bigone, monter
