Civil Engineering Association eBooks Journals, Papers and Presentations Mix proportion of eco-friendly fireproof high-strength concrete
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,704 in 1,304 posts
Given Likes: 4618
10-02-2012, 03:01 PM (This post was last modified: 10-02-2012, 03:02 PM by lisine.)
Author: Se Jin Choi, Soo-Hwan Kim, Su-Jin Lee, Rosa Won, Jong-Pil Won | Size: 0.94 MB | Format: PDF | Quality: Original preprint | Publisher: Construction and Building Materials, Vol 38 | Year: January 2013 | pages: 181–187 | ISSN: 0950-0618
The optimum mix proportion for eco-friendly fireproof high-strength concrete was derived in this study. The mixture of the concrete was evaluated by thermal performance through a fire-resistance test. To derive the optimum mix proportion, ground granulated blast-furnace slag and porcelain were substituted, and a 0.1 vol.% fraction of polypropylene fibre was added to prevent spalling. Porcelain was used, as it is effective in improving residual strength. The RABT curve was adopted as the heating time–temperature curve for the fire-resistance test. The derived optimum mix proportion can contribute to ecological friendliness, as it produced up to 34.6% CO2 savings compared with the mixture using conventional cement. Furthermore, improvement in the characteristics of concrete was shown after exposing this mixture to high temperature following the addition of porcelain.
[-] The following 5 users Like lisine's post:5 users Like lisine's post
  • zrilek, kowheng, Jackass, ykhackhack, Mohammad6299
  Prediction of Concrete Tensile Strength from its Compressive Strength: an Evaluation yakwetu 0 3,758 03-06-2017, 05:06 PM
Last Post: yakwetu
  Tensile Strength of Low, Medium, and High-Strength Concretes at Early Ages yakwetu 0 3,670 03-06-2017, 04:54 PM
Last Post: yakwetu
  SEISMIC PERFORMANCE OF HIGH-STRENGTH-CONCRETE HOLLOW BRIDGE PIERS UNDER MULTI-DIRECTI TAFATNEB 0 3,917 06-03-2014, 08:39 PM
  High Strength Concrete in Bridge Construction ir_71 0 3,601 07-12-2013, 07:58 AM
  Optimized Sections for High-Strength Concrete Bridge Girders—Effect of Deck Concrete ir_71 1 5,828 03-02-2013, 05:08 AM
Last Post: arshiakh
  STRENGTH–DUCTILITY PERFORMANCE OF FLANGED BEAM SECTIONS CAST OF HIGH-STRENGTH CONCRET asim99 0 4,080 12-29-2012, 12:06 AM
Last Post: asim99
  High Performance Concrete shadabg 0 3,280 12-27-2012, 10:30 AM
Last Post: shadabg
