CADVirusCure
Dear All,
Warning against AutoCAD Viruses around the world!
It is high time to make a check for AutoCAD Viruses - for FREE!
Your PC might be an unintentional contributor spreading
viruses to countless PC users.
Currently, this program can diagnose and cure 60 kinds of AutoCAD viruses.
But this Application runs at trial, you can Scan but cannot Cure,
anyone can help this for medicine?
As note:
Major symptoms of AutoCAD viruses
1. The screen does not work for around 5~30 minutes before it is activated when you initially execute CAD and open a drawing.
2. When you set the SDI system variable as 0, it will be back to be 1, which causes the CAD program to be multiply executed in opening a drawing.
3. The CAD command window shows you the following error prompt (In the English version)
* AutoCAD menu utilities loaded.; error: malformed list on input
* AutoCAD menu utilities loaded.; error: bad argument type: stringp nil
* AutoCAD menu utilities loaded.; error: bad character read (octal): 35
* ;error : LOAD Failed : "acad"
* ;error : LOAD Failed : "acaddoc"
* ;error : LOAD Failed : "acadapq"
* ;error : LOAD Failed : "acadapp"
* ;error : Macro not found.
* ;error: Function cancelled.
4. The LSP command you made does not work properly (acad.lsp acaddoc.lsp, etc.).
5. When you execute such commands as Line, Explode, Burst, Xbind, Xref and attedit, the screen reacts with the "Unknown command" message or asks you for inconsistent inputs.
6. Every folder whose drawing is open newly has the following files:
*acad.lsp
*acaddoc.lsp
*acadapp.lsp
*acadapq.lsp
*acadiso.lsp
*acaddoc.fas
*acad.vlx
*acad.sys
*acad.reg
*boot.bat
May this warning help us from trouble when pursue a deadline!
Peace for All
Dear all,
continuing my previous post:
I think this,my simple code can help us from disaster.
Peace for all,
Jupe
[-] The following 1 user says Thank You to jupe01 for this post:
  • asumi
Dear jupe01,
Please quote your lisp before post and make it yours.
I used this lisp along time ago. This code is made by a vietnamese person from cadviet forum
Dear all,
I post here cad antivirus and cad vaccine from CADViet forum
CADViet Antivirus: delete autocad virus
CADViet Vaccine: prevent virus infected
Miquan.
Yesterday is history, tomorrow is a Mystery, and today is a gift that is why it called the present.
[-] The following 4 users say Thank You to miquan for this post:
  • cace-01, oanm2000, Dell_Brett, henrybill
