ASCE - Improving MASW Results for a Site w Through the Use of Highith Shallow Bedrock
Improving MASW Results for a Site with Shallow Bedrock through the Use of Higher‐Mode Data
Author: Daniel et al | Size: 1.23 MB | Format: PDF | Quality: Unspecified | Publisher: GeoFlorida 2010: Advances in Analysis, Modeling & Design | Year: 2010 | pages: 1360 - 1368
In a case where the active-source multi-channel analysis of surface waves method was applied to a site consisting of clay residuum overlying basalt bedrock, inversion for the undamental-mode Rayleigh wave results in shear-wave velocities for the rock that are much lower than expected values. preliminary results from multi-mode inversions incorporating data from the 1st and 2nd higher-order modes provide more realistic velocities within the bedrock than could be obtained using the fundamental-mode data alone. However, the model data fit shows much room for improvement. Acquiring, processing and interpreting multi-mode data poses some challenges that need further research.
[-] The following 6 users say Thank You to melkat for this post:
  • oanm2000, kowheng, Jackass, giguni, Dell_Brett, zrilek
