Civil Engineering Association eBooks Structural Books Steel Handbook of Structural Steelwork-4th Ed.(printable)
 ahphuah
Junior Member
User ID: 1592
Threads: 11
Likes: 149 in 11 posts
Given Likes: 28
Points:513 EP
09-07-2009, 05:51 PM (This post was last modified: 09-08-2011, 12:51 PM by usman.)
[Image: 92650647628541547587.jpg]
_______________________________________________________________
The objective of this publication is to present a practical guide to the design of structural steel elements for buildings. The document comprises three principal Sections: general guidance, design data, and design tables.
The guidance is in accordance with BS 5950-1:2000, Structural use of steelwork in building – Code of practice for design. Rolled and welded section. Worked examples are presented where appropriate. No attempt has been made to consider complete structures, and it is to be noted therefore that certain important design matters are not dealt with – those for instance of overall stability, of interaction between components, and of the overall analysis of a building.
Section on General Design Data includes bending moment diagrams, shear force diagrams and expressions for deflection calculations. A variety of beams and cantilevers with different loading and support conditions are covered. Expressions for properties of geometrical figures are also given, together with useful mathematical solutions and metric conversion factors.
The design tables also include section property, member capacity and ultimate load tables calculated according to BS 5950-1:2000. The tables are preceded by a comprehensive set of explanatory notes. Section ranges listed are those that were readily available at the time of printing. In addition, both hot finished and cold formed structural hollow sections are included in the ‘Tables of Dimensions and Section Properties’.
(Post edited)
Download Links:
[-] The following 37 users Like ahphuah's post:37 users Like ahphuah's post
  • Dell_Brett, Dell_Brett, rohailiyaz, rohailiyaz, vvvv, vvvv, chenamoy, chenamoy, zrilek, zrilek, ajmf77, ajmf77, orambo, orambo, telefere, telefere, hcardenas, quatermain, duazo2009, cesar3226, Umer.Aleem, w64bit, rkce, oanm2000, ting tsai huang, narendra, dersaar, foxxx2010, jcbv, Nilupa, warbeast, subin91, ikoleci, Quantumm, bigone, sacem, harsono
Points:178,871 EP
09-08-2011, 09:16 AM
Size: 2.9 MB | Format: PDF | Publisher: BSCA & SCI | Year: 2007 | pages: 393 | ISBN: 1859421741
FOREWORD
The objective of this publication is to present a practical guide to the design of structural steel elements for buildings. The document comprises three principal Sections: general guidance, design data, and design tables. The guidance is in accordance with BS 5950-1:2000, Structural use of steelwork in building – Code of practice for design. Rolled and welded section. Worked examples are presented where appropriate. No attempt has been made to consider complete structures, and it is to be noted therefore that certain important design matters are not dealt with – those for instance of overall stability, of interaction between components, and of the overall analysis of a building. Section on General Design Data includes bending moment diagrams, shear force diagrams and expressions for deflection calculations. A variety of beams and cantilevers with different loading and support conditions are covered. Expressions for properties of geometrical figures are also given, together with useful mathematical solutions and metric conversion factors. The design tables also include section property, member capacity and ultimate load tables calculated according to BS 5950-1:2000. The tables are preceded by a comprehensive set of explanatory notes. Section ranges listed are those that were readily available at the time of printing. In addition, both hot finished and cold formed structural hollow sections are included in the ‘Tables of Dimensions and Section Properties’. A list of references is given at the end of the branding explanation pages. Foreword to the 4th edition. This edition has only been modified to include the new range of sections. It provides the Advance, Celsius and Hybox branding in addition to the BS section designations. The relationship between the branded sections/steel grades and the BS sections/steel grades is given in section 11 of the explanatory notes.
[-] The following 45 users Like ir_71's post:45 users Like ir_71's post
  • Dell_Brett, kowheng, cordoba123, concreteok, isurya, ibg0203, Visitante, vardan, rkce, seriousboy, oanm2000, Trishu999, malc, salahcivil, jferrer, Adam Smith, nuttapolk, DamaD, ting tsai huang, zrilek, tluc, NBZ1400, foxxx2010, lasalleguy, sangen, kerenski_t, simanta, sodapas, Rihpi, draluka, cristi, jcbv, kmmh76, mowafi3m, gulilero, shanta, we_mbm, Draculina, kvtasp, Nilupa, lednar_ved, warbeast, Quantumm, bigone, tunaungkyaw
 3fan
Romania
User ID: 29614
Threads: 161
Likes: 7,359 in 1,207 posts
Given Likes: 5545
Points:62,946 EP
07-17-2012, 05:51 AM
DIRECT LINKS thumbup
[-] The following 8 users Like 3fan's post:8 users Like 3fan's post
  • jcbv, lisine, slowet, oanm2000, Jackass, Dell_Brett, bigone, harsono
Points:66,329 EP
07-18-2012, 05:13 AM (This post was last modified: 07-18-2012, 05:16 AM by shadabg.)
Direct Link :
Mirror Link :
For 3rd Edition:
[-] The following 8 users Like shadabg's post:8 users Like shadabg's post
  • blaze, 3fan, Dell_Brett, gulilero, psycin, demertis, bigone, tunaungkyaw
 vinnunsam
User ID: 3932
Threads: 36
Likes: 1,281 in 116 posts
Given Likes: 457
Points:9,083 EP
02-18-2014, 09:15 AM
SCI P201 HandBook of Structural SteelWork 4rd Edtion 2002
Size: 2.73 MB | Format: PDF | Quality: Unspecified | Publisher: The Steel Construction Institute | Year: 2002 | pages: 393
[Image: 12518178547535104507.jpg]
[-] The following 12 users Like vinnunsam's post:12 users Like vinnunsam's post
  • bigone, draluka, Andrew seah, malc, marion33, PinkPant, tunaungkyaw, zrilek, milova, jcbv, yanburak, bridgeengineer
  Introduction to the Economics of Structural Steelwork mastermind 4 3,124 02-15-2017, 12:28 AM
Last Post: RyanRS
  Structural steelwork: analysis and design abudabeeja 9 6,219 12-04-2015, 08:09 PM
Last Post: cargadory2k
  Structural Steelwork: Design to Limit State Theory: T.J. MacGinley, T.C. Ang babak 9 6,572 11-10-2015, 02:37 AM
Last Post: ibg0203
  Structural steelwork connections abudabeeja 4 5,426 09-13-2014, 07:49 PM
  Semi-Rigid Joints in Structural Steelwork amindoxiti 1 1,795 09-12-2014, 07:35 PM
Last Post: Saze808
  Limit States Design of Structural Steelwork - by David Nethercot abudabeeja 7 6,561 07-13-2014, 03:39 PM
Last Post: i_kabir
  Typical Welding Procedure Specifications for Structural Steelwork arshiakh 0 1,152 03-04-2013, 04:11 PM
Last Post: arshiakh
