Civil Engineering Association eBooks Structural Books Steel Welding: Processes, Quality, and Applications
 junaid
User ID: 402
Threads: 209
Likes: 8,170 in 732 posts
Given Likes: 983
Points:34,110 EP
10-15-2011, 09:49 AM
Author: Richard J. Klein | Size: 10.1 MB | Format: PDF | Publisher: Nova Science Pub Inc. | Year: 2010 | pages: 428 | ISBN: 1617613207
[Image: 09595152986368601357.jpeg]
Welding is a fabrication or sculptural process that joins materials, usually metals or thermoplastics, by causing coalescence. This is often done by melting the workpieces and adding a filler material to form a pool of molten material (the weld pool) that cools to become a strong joint, with pressure sometimes used in conjunction with heat, or by itself, to produce the weld. This book presents current research data in the study of welding, including the design of high brightness welding guns; electron beam welding; friction stir welding; limit load solutions for highly under-matched welded joints; fracture and fatigue assessment of welded structures; and, laser transmission welding.
[-] The following 17 users Like junaid's post:17 users Like junaid's post
  • miquan, seriousboy, Dell_Brett, kowheng, jcbv, zrilek, ibg0203, dinu69in, hcardenas, spiderthan, eliseo.as, Jackass, gulilero, ting tsai huang, jjmtz, Nilupa, andersen3
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 264
Likes: 19,031 in 2,186 posts
Given Likes: 42448
Points:111,158 EP
10-16-2011, 09:16 AM
[-] The following 9 users Like Dell_Brett's post:9 users Like Dell_Brett's post
  • junaid, araza023, zrilek, blaze, jcbv, gulilero, Nilupa, baikur, saed
  Welding Skills, Processes and Practices for Entry-Level Welders 1-3 febo927 2 1,279 06-11-2018, 01:08 PM
Last Post: febo927
  Welding: Principles and Applications - Larry Jeffus r3be1 3 2,022 06-08-2018, 06:35 AM
  Handbook of Structural Welding, Processes, materials and methods used in the welding arshiakh 2 2,203 02-11-2015, 04:07 AM
Last Post: Veggeta
  Processes and Mechanisms of Welding Residual Stress and Distortion abudabeeja 3 2,220 07-18-2014, 07:30 AM
  Surface Phenomena in Fusion Welding Processes struceng 2 1,915 02-26-2014, 07:10 AM
Last Post: Mohammad6299
  Resistance welding: fundamentals and applications abudabeeja 3 2,370 11-16-2012, 07:50 AM
