Civil Engineering Association eBooks Journals, Papers and Presentations Optimal seismic performance-based design of reinforced concrete buildings using non..
 cve_jule
Macedonia
User ID: 6973
Threads: 32
Likes: 888 in 90 posts
Given Likes: 882
Points:5,160 EP
09-09-2011, 07:25 AM
Optimal seismic performance-based design of reinforced concrete buildings using nonlinear pushover analysis
Author: X.-K. Zou, C.-M. Chan | Size: 1.75 MB | Format: PDF | Publisher: Engineering Structures | Year: 2005 | pages: 14
[Image: 63741028707663156757.jpg]
Abstract
Performance-based design using nonlinear pushover analysis, which generally involves tedious and intensive computational effort, is a highly iterative process needed to meet designer-specified and code requirements. This paper presents an effective computer-based technique that incorporates pushover analysis together with numerical optimization procedures to automate the pushover drift performance design of reinforced concrete (RC) buildings. Steel reinforcement, as compared with concrete materials, appears to be themore cost-effective material, that can be effectively used to control drift beyond the occurrence of first yielding and to provide the required ductility of RC building frameworks. In this study, steel reinforcement ratios are taken as design variables during the design optimization process. Using the principle of virtual work, the nonlinear inelastic seismic drift responses generated by the pushover analysis can be explicitly expressed in terms of element design variables. An optimality criteria technique is presented in this paper for solving the explicit performance-based seismic design optimization problem for RC buildings. Two building frame examples are presented to illustrate the effectiveness and practicality of the proposed optimal design method.
© 2005 Elsevier Ltd. All rights reserved.
Keywords: Performance-based design; Pushover analysis; Virtual work; Plastic hinge; Structural optimization design; Optimality criteria method
[-] The following 14 users Like cve_jule's post:14 users Like cve_jule's post
  • kowheng, pedzaquino, Dell_Brett, zrilek, oanm2000, ruaumoko, blaze, sodapas, Jackass, malc, gulilero, Clouseau, rezart, psk62
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 11,844 08-01-2017, 09:19 AM
Last Post: abdulazizk
  Performance-based seismic assessment of skewed bridges bridgeengineer 0 4,803 04-22-2016, 06:31 AM
Last Post: bridgeengineer
  Seismic evaluation of a 56-storey residential reinforced concrete high-rise building anfaga 3 8,243 02-10-2016, 02:49 PM
  2nd ATC-SEI Conference on Improving the Seismic Performance of Existing Buildings and RyanRS 0 4,890 10-29-2015, 12:55 AM
Last Post: RyanRS
  Assessment of the seismic performance of a bituminous faced rockfill dam Wolverine883 0 5,565 07-19-2015, 07:24 AM
Last Post: Wolverine883
  Seismic Design of Concrete Structures - The Present Needs of Societies RyanRS 0 5,219 05-17-2015, 05:49 AM
Last Post: RyanRS
  Performance based earthquake design using the CPT PinkPant 0 5,346 05-14-2015, 08:17 AM
Last Post: PinkPant
