Autodesk AutoCAD Plant3D 2012 (x86/x64)
Current time: 07-23-2018, 07:06 AM
Author: BennyP
Replies 6
Views 4496
[Image: 22166571860014333887.gif]
[Image: 35145994573555032454.gif]
[Image: 89282942539428038049.gif]
Design, model, and document process plants with AutoCAD® Plant3D software. Built on the familiar AutoCAD® software platform, AutoCAD Plant3D brings modern 3D design to plant designers and engineers. Specification-driven design and standard parts catalogs streamline the placement of piping, equipment, and support structures. Integrated AutoCAD® P&ID software functionality enables you to create and edit P&IDs and reconcile underlying data with the 3D model. Generate and share isometrics, orthographics, and other documents.
Features:
Workspace—Purpose-built user interface for 3D plant design.
Specifications and catalogs—Spec-driven technology and standard parts catalogs (ANSI/ASME (B16) and DIN/ISO). Modify catalogs to meet project requirements.
Piping, equipment, and structure—Model spec-driven pipelines and components semiautomatically or manually. Includes a customizable library of standard equipment elements. Externally reference or parametrically create structural elements. Identify interferences.
Construction documents—Generate accurate isometrics, orthographics, and other documents.
Search and report—Query and manipulate data. Generate materials reports. Export to PCF files.
AutoCAD P&ID integration—Integrated functionality enables data consistency.
Autodesk Navisworks compatibility—Seamlessly perform whole-project review.
Spec converter—Import specs from other applications.
[Image: homepage.png]
[-] The following 6 users say Thank You to BennyP for this post:
  • sasan7351, Dell_Brett, oanm2000, jakoben, 3fan, plngage
Other links:
  • Dell_Brett, oanm2000, 3fan
And other links:
  • oanm2000, 3fan
Other links:
  • 3fan
Other links (64bit)
  • hcardenas, 3fan
Autodesk AutoCAD Plant3D 2012 1.98 GB
  • 3fan
Autodesk AutoCAD Plant 3D 2012 SP2 2.4GB
Autodesk AutoCAD v2010 x86 & x64 Eng (DVD-ISO) [NoPE]+AutoCAD Civil 3D 2009 kamran 1 2,550 04-20-2014, 08:31 PM
Last Post: cenlara
Autodesk Products 2012 x-force keygen for x32 systems BennyP 5 8,116 02-03-2013, 01:20 PM
Last Post: KhaLed-S.E
Autodesk AutoCAD LT 2012 x32 x64 ISO BennyP 12 7,744 12-17-2012, 04:32 PM
Autodesk Subscription 2012 MegaPack BennyP 9 8,386 03-18-2012, 09:36 PM
Last Post: oasis_tree
Portable Autocad 2012 - x32 BennyP 4 5,176 03-13-2012, 09:05 AM
Last Post: psppsp
