Civil Engineering Association eBooks Journals, Papers and Presentations Guide to the Design and Application of BBR FRP Strengthening Systems
07-27-2011, 05:11 PM (This post was last modified: 06-11-2012, 12:35 PM by lisine.)
Size: 4.1 MB | Format: PDF | Publisher: BBR Systems | Year: 2002 | pages: 101
[Image: 38694512932005086527.jpg]
This document offers a guide to the design and application of BBR FRP materials used in the strengthening of concrete and timber structures. It addresses strengthening by the application of carbon fibre reinforced polymers (CFRP), aramid fibre reinforced polymers (AFRP) and glass fibre reinforced polymers (GFRP) to the external parts of structural elements, both by bonding to the external surface and/or bonding within slots cut in the surface layers of the substrate.
BBR Systems Ltd has produced this manual for use by its BBR subsidiaries and licensees worldwide. The information contained herein has been researched from a number of references and is considered current as at the date given at the bottom of this page. As the use of FRPs is the subject of a large number of on-going research programmes around the world, conditions pertaining to their usage may vary from time to time.
BBR Systems Ltd does not warrant the correctness of the material provided in this manual and shall not be liable for any special, incidental, consequential, indirect or any damages whatsoever, which arise out of any breach of warranty, breach of contract, tort, strict liability or any other cause of action. The successful application and use of this manual is the sole responsibility of the user and is dependent on the application of sound judgement by a qualified Engineer who has a thorough understanding of structural mechanics and material behaviour, especially as it relates to reinforced concrete. The user of the manual must ensure that the design procedure adopted is relevant for use on the intended application and must select appropriate values suitable for the specific application. Reference to an appropriate set of Design Recommendations is essential (either the German General Guidelines, The UK Concrete Society Design Guidance TR55, the fib bulletin 14 or the draft ACI 440 Recommendations would be appropriate documents for this purpose). Any design carried out must comply with the relevant Codes of Practice for the country concerned.
The manual is not to be relied on as the sole basis for design. Procedures contained in the manual, if adopted, imply that the user acknowledges and agrees to the terms of usage outlined above and further implies that the user understands the manual has been prepared to supplement the user’s knowledge on this specialised subject. Any implied or expressed warranties covering this manual, including any warranties of fitness for particular purpose and warranties with respect to effect or result of the application of the manual to specific strengthening work and any warranties with respect to the completeness or effectiveness of the repair or strengthening for which the manual was used is expressly excluded.
It is envisaged that Chapters 6, 7 & 8 will be upgraded regularly as the divergence of opinion which exists between current guidelines comes closer together. The material contained therein should be taken as introductory at this stage.
[-] The following 19 users Like ir_71's post:19 users Like ir_71's post
  • kowheng, blaze, niki102, versiondemo, zrilek, jcbv, oanm2000, pabulumzeng, LadaHitam, malc, Jackass, toa011, fashion, tluc, Clouseau, ibmarin, warbeast, ykhackhack, Dell_Brett
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,704 in 1,304 posts
Given Likes: 4618
06-11-2012, 12:46 PM (This post was last modified: 06-11-2012, 12:46 PM by lisine.)
Direct link (This is locked version - Printing allowed - Content editing/copying not allowed)
This is unlocked version (No restriction on editing or copying) / 4.11MB
[-] The following 11 users Like lisine's post:11 users Like lisine's post
  • jcbv, blaze, ykhackhack, SCREAM7890, kowheng, Jackass, zrilek, chenamoy, Dell_Brett, ting tsai huang, uetian19
Likes: 8,185 in 1,337 posts
02-12-2022, 08:08 AM
Size: 3.97 MB | Format: PDF | Publisher: BBR Systems | Year: 2002 | pages: 101
  • babakfeyzi, jcbv, cace-01, Dell_Brett, milova, CAMSECT, subin91, oanm2000, gulilero
  Philosopy and Application of Capacity Design Sumatra 1 5,053 04-10-2015, 01:21 PM
Last Post: monter
  EISMIC EVALUATION AND STRENGTHENING OF EXISTING REINFORCED CONCRETE BUILDINGS — GUIDE TAFATNEB 0 4,632 04-12-2014, 10:06 PM
  Guide for the Selection of Strengthening Systems for Concrete Structures ir_71 0 4,281 07-15-2011, 04:27 PM
