Civil Engineering Association eBooks Journals, Papers and Presentations A performance-based adaptive methodology for the seismic evaluation of...
 cve_jule
Macedonia
User ID: 6973
Threads: 32
Likes: 888 in 90 posts
Given Likes: 882
07-15-2011, 10:18 AM (This post was last modified: 07-15-2011, 10:12 PM by oanm2000.)
A performance-based adaptive methodology for the seismic evaluation of multi-span simply supported deck bridges
Author: Donatello Cardone · Giuseppe Perrone · Salvatore Sofia | Size: 1.24 MB | Format: PDF | Publisher: Bull Earthquake Eng | Year: 2011 | pages: 36
[Image: 51298769152547907993.jpg]
Bull Earthquake Eng
DOI 10.1007/s10518-011-9260-8
ORIGINAL RESEARCH PAPER
Received: 18 December 2009 / Accepted: 22 March 2011
© Springer Science+Business Media B.V. 2011
Abstract:
A performance-based adaptive methodology for the seismic assessment of highway bridges is proposed. The proposed methodology is based on an Inverse (I), Adaptive (A) application of the Capacity Spectrum Method (CSM), with the capacity curve of the bridge derived through a Displacement-based Adaptive Pushover (DAP) analysis. For this reason, the acronym IACSM is used to identify the proposed methodology. A number of Performance Levels (PLs), for which the seismic vulnerability and seismic risk of the bridge shall be evaluated, are identified. Each PL is associated to a number of Damage States (DSs) of the critical members of the bridge (piers, abutments, joints and bearing devices). The IACSM provides the earthquake intensity level (PGA) corresponding to the attainment of the selected DSs, using over-damped elastic response spectra as demand curves. The seismic vulnerability of the bridge is described by means of fragility curves, derived based on the PGA values associated to each DS. The seismic risk of the bridge is evaluated as convolution integral of the product between the fragility curves and the seismic hazard curve of the bridge site. In this paper, the key aspects and basic assumptions of the proposed methodology are presented first. The IACSM is then applied to nine existing simply supported deck bridges, characterized by different types of piers and bearing devices. Finally, the IACSM predictions are compared with the results of nonlinear response time-history analysis, carried out using a set of seven ground motions scaled to the expected PGA values.
[-] The following 10 users Like cve_jule's post:10 users Like cve_jule's post
  • malc, jcbv, blaze, kowheng, cigutierrezg, oanm2000, Dell_Brett, Jackass, tluc, zrilek
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 12,272 08-01-2017, 09:19 AM
Last Post: abdulazizk
  Performance-based seismic assessment of skewed bridges bridgeengineer 0 5,110 04-22-2016, 06:31 AM
Last Post: bridgeengineer
  Seismic evaluation of a 56-storey residential reinforced concrete high-rise building anfaga 3 8,733 02-10-2016, 02:49 PM
  2nd ATC-SEI Conference on Improving the Seismic Performance of Existing Buildings and RyanRS 0 5,201 10-29-2015, 12:55 AM
Last Post: RyanRS
  Assessment of the seismic performance of a bituminous faced rockfill dam Wolverine883 0 5,863 07-19-2015, 07:24 AM
Last Post: Wolverine883
  Performance based earthquake design using the CPT PinkPant 0 5,598 05-14-2015, 08:17 AM
Last Post: PinkPant
  Performance –Based Design emmi 2 7,676 03-24-2015, 10:10 AM
Last Post: ssobhan
