Civil Engineering Association eBooks Structural Books Steel Prescriptive Method For Residential Cold-Formed Steel Framing Year 2000 Edition
Points:178,871 EP
07-14-2011, 04:39 PM
Author: Nader R. Elhajj, P.E. and Kevin Bielat | Size: 1.5 MB | Format: PDF | Publisher: NASFA | Year: 2000 | pages: 199
[Image: 43792806575000825445.jpg]
The year 2000 edition of the Prescriptive Method for Residential Cold-Formed Steel Framing (Prescriptive Method) was developed as a guideline for the construction of one- and two-family residential dwellings using coldformed steel framing. It provides a complete prescriptive approach to build typical homes with cold-formed steel framing. This document is based on standardized basic cold-formed steel members, provides labeling guidelines, and gives minimum corrosion protection recommendations. It also includes floor joist span tables, ceiling joist span tables, rafter span tables, wall stud tables, header span tables, wall bracing requirements, and connection requirements. The requirements are supplemented with construction details where required. The year 2000 edition includes improvements upon the second edition in the following areas:
- Enhanced wall bracing requirements for high wind and seismic conditions
- Floor joist tables for 19.2" spacing and tables for joists not requiring web stiffeners
- Header tables for bottom story of a two-story building with center load bearing beam
- L-Header tables and details
- Floor and wall anchoring details
- Added tables and details for non-load bearing walls
- Curtain wall tables
- Ceiling joist tables not requiring web stiffeners
- Expanded thermal, mechanical, electrical, and HVAC guidelines
- New section on “How to Use the Prescriptive Method”
[-] The following 21 users Like ir_71's post:21 users Like ir_71's post
  • kowheng, gatob, NBZ1400, ibg0203, hcardenas, malc, jferrer, oanm2000, ting tsai huang, tluc, Dell_Brett, dinu69in, niki102, cristi, Jackass, kmmh76, slowet, baikur, ykhackhack, lednar_ved, warbeast
Likes: 33,527 in 2,936 posts
Points:158,166 EP
09-02-2012, 05:55 AM
PDF 1.54 MB | RAR 1.28 MB
[-] The following 20 users Like kowheng's post:20 users Like kowheng's post
  • lednar_ved, ykhackhack, Jackass, concreteok, Dell_Brett, david-smith, pedzaquino, blaze, jcbv, warbeast, ruaumoko, oscargon, Albert, odiclas, eliseo.as, chenamoy, sola4466, oanm2000, Nim., pram
  Cold-Formed Tubular Members and Connections. Structural Behaviour and Design TAFATNEB 0 2,367 04-25-2023, 10:48 AM
  Cold-Formed Steel Design Flexi 21 15,555 09-03-2022, 04:21 AM
  Recent Trends in Cold-Formed Steel Construction struceng 0 1,293 03-15-2017, 09:43 AM
Last Post: struceng
  Cold-formed Tubular Members and Connections choonguan 10 7,753 12-16-2015, 11:25 PM
Last Post: cargadory2k
  SCI P332: Steel in Multi-Storey Residential Buildings ir_71 5 3,562 06-17-2015, 04:42 AM
Last Post: f_slikken
  Design of Metallic Cold-Formed Thin-Walled Members babak 8 3,999 01-03-2015, 11:34 PM
Last Post: Veggeta
  SCI P301: Building Design using Cold Formed Steel Sections: Light Steel Framing in Re ir_71 2 2,667 11-13-2014, 08:42 AM
Last Post: concreteok
