Civil Engineering Association Various Free Discussion Question about pre-dimensioning
 MOHAMMED
User ID: 14769
Threads: 1
Likes: 0 in 0 posts
Given Likes: 0
Points:200 EP
06-12-2011, 03:45 PM (This post was last modified: 06-12-2011, 09:32 PM by Dell_Brett.)
hi everyone ..
I have a Question:
when we design a building , how do we get its dead load as we do not have the dimensions from the beginning ? i recall one of my instructors said that we generate a preliminary design then we modify it .. can someone elaborate on this ??
I need a clear answer ..
thnx
 ishvaaag
Spain
User ID: 12045
Threads: 5
Likes: 259 in 83 posts
Given Likes: 28
Points:7,581 EP
06-12-2011, 04:20 PM
Normally any building design starts by some architectural definition. A proficient architect is able to specify both tentative dimensions and structural systems convenient to structural safety and good use, even if he himself is not to produce later the structural design.
Then any structural designer has something with what to start; some specific kind of foundation, structural system, structural devices will be pre-defined; and some non-structural items will be stated as the components to cause dead loads; some uses will be specified for the parts of the building.
Fron such data and resourcing to code load data, say ASCE 7, you define the loads for your building. Of course such loadings are derived from previous experience on the particular items referred in the articles and are thought to lead to economically bearable, consistently safe and socially accepted standards of building construction.
[-] The following 2 users Like ishvaaag's post:2 users Like ishvaaag's post
  • mojtaba808, Dell_Brett
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 264
Likes: 19,029 in 2,185 posts
Given Likes: 42446
Points:111,098 EP
06-12-2011, 09:44 PM
Dear Mohammed,
It's usual starts a design with some practical dimensions. For example: -for concrete beans, we starts with the equivalent height of 8% to 10% of span.
After pre-dimensioning, we check if deformations, moments, shear forces, etc, are compatible with our preliminary pre-dimensioning.
Now, we starts a try-and-error changes until the structure is OK!
Naturally, experienced structural engineers can do this with only few interactions...
If you need more explanations, please returns with clear points that you don't understand.
Dell Brett
[-] The following 2 users Like Dell_Brett's post:2 users Like Dell_Brett's post
  • giga, oanm2000
 seb3k
User ID: 7801
Threads: 5
Likes: 147 in 63 posts
Given Likes: 156
Points:3,873 EP
06-12-2011, 10:46 PM
As dell said.
you can find tables with pretty much standard dimensions of elements.
like for beams... span/10
for solid concrete slab... span/35...add some standardized additional dead loads for flooring, lets say 0.75kn/m2,
add live load as per code...such as 3kn/m2 for residential spaces, and you have a good starting point
[-] The following 1 user Likes seb3k's post:1 user Likes seb3k's post
  • Dell_Brett
