Civil Engineering Association eBooks Structural Books Steel SCI P148: Modelling of Steel Structures for Computer Analysis
Points:178,871 EP
05-12-2011, 05:13 AM
Size: 3.1 MB | Format: PDF | Publisher: SCI | Year: 1995 | pages: 74 | ISBN: 1859420257
[Image: 52896557039789475786.jpg]
This document gives guidance on the creation of computer models for steel structures with orthodox details and connections in order to produce safe, cost effective, real structures. It is primarily aimed at structural engineers using readily available analysis software. It highlights the importance of a qualitative understanding of structural response both during the creation of the analysis model and whilst appraising the analysis output.
After a general introduction to the elastic, plastic and elastic-plastic analysis of two and three dimensional frames, separate chapters address the modelling of:
- a simple beam and column frames
- a trusses and lattice girders
- a portal frames
- a curved, tapered and non homogeneous members connections
- a supports
- a loads
It also provides guidance on simple checks to ensure the analysis is correct and an overview of member design for the less experienced designer.
This guide is limited to the modelling of general building and plant structures of normal proportions under static loading. Offshore structures, masts, bridges, shells and plates are not covered, nor is grillage analysis. The guide concentrates on first order analysis programs. Second order analysis is discussed, but both the analysis and the type of structure requiring second order analysis are outside the scope of this document.
[-] The following 71 users Like ir_71's post:71 users Like ir_71's post
  • kowheng, rohailiyaz, theanhpe, abalcu, knrsa, nohahassan, Jackass, robertsas, malc, 3fan, blaze, vvvv, giga, melkat, Dell_Brett, Clouseau, Umer.Aleem, miquan, seriousboy, ArissB, concreteok, lednar_ved, ikoleci, toa011, allagui10, yucapareja, tamboon, hcardenas, chairatpk, Veggeta, sodapas, Ivan_1980, foxxx2010, oanm2000, ziggywas1, jferrer, orambo, mastermind, zrilek, carolinandra, manoj, tluc, dinu69in, subin91, ladjin, simanta, cristi, xpressmusic, monter, vardan, rezart, bigone, wa_sin_29, jcbv, ramla2002, iluso81, albert23rd, Sumatra, kmmh76, engrezi, user108, visu, baikur, ting tsai huang, tang1942, gulilero, ykhackhack, jonny78, newbie5, melekeen, tuanpecc1
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
Points:29,008 EP
11-15-2012, 04:37 PM
all links dead; direct link
[-] The following 26 users Like andersen3's post:26 users Like andersen3's post
  • pelon2040, Jackass, Quantumm, hmwere, gulilero, Dell_Brett, Trishu999, ykhackhack, ssi3k, chenamoy, k2kyaw, KhaLed-S.E, Pinkto, terrorruban, miquan, jonny78, apocalipse, levanduy, simanta, stigtg, bigone, demertis, narendra, ruaumoko, Aviator, kowheng
 malee
User ID: 554
Threads: 17
Likes: 1,358 in 98 posts
Given Likes: 267
Points:3,860 EP
10-18-2018, 07:16 AM
[-] The following 21 users Like malee's post:21 users Like malee's post
  • blaze, Andrew seah, melekeen, Aviator, febo927, carolinandra, jcbv, Nita1391, moh_towhid, sodapas, emmi, PinkPant, tuanpecc1, oanm2000, Dell_Brett, munycamsec, tomtumx, lasalleguy, yanburak, kowheng, babakfeyzi
  Modelling Steel and Composite Structures TAFATNEB 0 2,496 04-25-2023, 10:57 AM
  Design and Analysis of Connections in Steel Structures: Fundamentals and Examples amindoxiti 1 2,094 12-16-2018, 07:54 AM
Last Post: malee
  Plastic Analysis and Design of Steel Structures Ultra Zone 11 6,124 08-01-2018, 01:09 PM
Last Post: febo927
  Analysis and Design of Steel and Composite Structures cace-01 3 3,467 03-18-2018, 03:37 AM
Last Post: gulilero
  Steel Structures: Analysis and Design for Vibrations and Earthquakes i_kabir 3 2,508 12-02-2015, 03:15 PM
Last Post: temp1366
