CG Academy: 3DS Max Collection (32 DVD) -updating
01. CG Academy: 3dsmax Workflow 1
[Image: 25801ut.jpg]
This DVD introduces the 3dsmax user interface and its unique workflow. In the first half of this DVD you will be taken through all of the user interface elements of 3dsmax, and this exploration continues in the second section where Chris creates a simple scene that demonstrates many core features of 3dsmax.
This DVD is aimed at a basic level 3d user, someone with knowledge of how to operate software in general and with a basic understanding of 3d software concepts. It is designed to give the user an introduction to 3dsmax and not to 3d concepts in general. It is also of particular use to those moving over to 3dsmax from another 3d graphic platform.
Pass to download:
Quote:3dzip.net
02. CG Academy: 3dsmax Workflow 2
[Image: vxkls7.jpg]
This DVD is the first of a two part series that introduces Proceduralism within 3dsmax. Chris guides you through the concepts of a nodal architecture by looking at practical examples in 3dsmax , Maya and Houdini , and goes on to show how it is accessed in Max via its Stack interface. He then continues onwards to show how large and small elements can be instanced, and outlines important issues such as stack evaluation and topological dependency.
This DVD is aimed at a user of Fundamental to Intermediate level. It is intended to give a good grounding in the Procedural concepts and workflows in 3dsmax, and also as a strong foundation upon which the user can build their skills in DVD 2 in this series Procedural Techniques .
Homepage:
Mediafire:
Pass to download:
Quote:3dzip.net
03. CG Academy: Modelling Fundamentals 1
[Image: 2uo2k52.jpg][/code]
This is the first in a four DVD series that aims to teach the fundamentals of modelling in 3dsmax. In this first DVD you will learn how to effectively navigate and manipulate objects in 3D space. Then the DVD moves on to teach you what polygons are and how they are fundamental to all modelling systems. Then we learn about Primitives and how we can change their form using Modifiers and Spacewarps. And finally we make a start on a series wide project to build a go-cart using the skills developed in this DVD.
This DVD is aimed at a user who is new to 3dsmax and modelling. The DVD makes no assumptions about your 3D knowledge and aims to give you a ground up tuition in modelling. Its topics are wide ranging and form a foundation for the DVDs that follow in this series.
Homepage:
Pass to download:
Quote:3dzip.net
04. CG Academy: Modelling Fundamentals 2
[Image: s485zd.jpg]
This DVD continues our series on modelling fundamentals by exploring polygonal modelling. You will be shown the key differences between the Edit Mesh and Edit Poly geometry types. You’ll be shown the main elements of mesh editing, including creating polygons from scratch, attaching and detaching meshes, flipping Normals, modifying smoothing groups and material IDs, ring selection and division, bevelling and much more.
This DVD is aimed at a user who is new to 3dsmax and modelling. The DVD assumes the user has completed DVD1 in this series, or has the skills equivalent to those taught in that DVD.
Pass to download:
Quote:3dzip.net
I will update tomorrow,
Ps: I am Vietnamese and English is not good. I want to share something which I have.
Thanks you readme.
[-] The following 10 users say Thank You to timosi™ for this post:
  • yucapareja, yucapareja, Dell_Brett, Dell_Brett, marife, marife, NiMoAb, NiMoAb, Cirrus, Cirrus
[Image: s485zd.jpg]
[-] The following 6 users say Thank You to timosi™ for this post:
  • Dell_Brett, Dell_Brett, NiMoAb, NiMoAb, Cirrus, Cirrus
05. CG Academy: Modelling Fundamentals 3
[Image: 2ngx8qo.jpg]
This DVD continues our look at the fundamentals of modelling in 3dsmax. Here we focus on 3dsmax’s curve based modelling toolset, which is based on Bezier Splines. You’ll be shown how to create Splines from scratch, or via the numerous built in templates. How to edit and combine those Splines into more complex forms. How to use the Extrude, Lathe and Loft Tools to create complex custom surfaces. We continue our series spanning go-cart modelling project. And we conclude with a quick look at Splines use in animation.
This DVD is aimed at a user who is new to modelling in 3dsmax. The DVD assumes the user has completed DVDs 1 and 2 in this series, or that they have the skills equivalent to those taught in those DVDs.
Homepage:
[Image: Mediafirecom.gif]
06. CG Academy: Modelling Fundamentals 4
[Image: 2r4hqj6.jpg]
In this DVD we conclude our modelling fundamental series by tackling the subject of sub-division surface modelling. Chris will introduce you to the philosophy and technology behind sub-d surfaces, how to create them within 3dsmax and how to effectively model using them. We use those skills to model a number of elements on our go-cart model. We look at how we can optimize our sub-d workflow, and mix our techniques to more effectively model. And Chris concludes the DVD and series with an exploration of some best working practices and tips and tricks.
This DVD is aimed at a user who is new to modelling in 3dsmax. The DVD assumes the user has completed DVDs 1, 2and 3 in this series, or that they have the skills equivalent to those taught in those DVDs.
[-] The following 4 users say Thank You to timosi™ for this post:
  • NiMoAb, NiMoAb, Cirrus, Cirrus
