Civil Engineering Association eBooks Structural Books Steel SCI P304 Guide to the major amendments in BS 5950-1:2000
Points:178,871 EP
04-14-2011, 05:44 AM
Author: M Heywood | Size: 1.6 MB | Format: PDF | Publisher: SCI | Year: 2001 | pages: 96 | ISBN: 1859421318
[Image: 02447826589522094466.jpg]
BS 5950 Structural use of steelwork in building, Part 1: Code of practice for design - Rolled and welded sections has undergone major amendment. Almost every Clause of this widely used Standard has changed in some way; some of the changes are technical in nature, others are editorial and do not alter the recommendations for building design. The revised Standard, referred to as BS 5950-1:2000, became effective on 15 August 2001.
The aim of this publication is to ease the transition to BS 5950-1:2000 by guiding designers through the major technical amendments to the Standard. A short description of each important change is provided, and simple worked examples illustrate the revised design procedures.
The major amendments to BS 5950-1 include revised rules for checking the stability of frames, changes to the method for selecting an appropriate steel sub-grade and the introduction of the effective-area method for class 4 slender sections. On the subject of member design, the greatest change relates to lateral-torsional buckling, where the n-factor method has been removed. Changes have also been made to the Clauses on shear buckling, stiffener design, tension members, compression members, combined axial load and bending, and the design of column bases. Elsewhere, important changes have been made to the rules relating to the in-plane stability of portal frames, prying forces and the transverse strength of fillet welds.
[-] The following 21 users Like ir_71's post:21 users Like ir_71's post
  • visu, kowheng, knrsa, blaze, malc, vvvv, seriousboy, Dell_Brett, hmwere, jferrer, oanm2000, toa011, zrilek, Nilupa, robertsas, truca, monter, jcbv, kmmh76, mahyarov, bigone
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
Points:29,008 EP
11-16-2012, 10:09 AM
all links dead; mirror
password
  • blaze, bigone, Dell_Brett
 bigone
User ID: 4505
Threads: 92
Likes: 5,722 in 517 posts
Given Likes: 7145
Points:24,374 EP
12-18-2013, 11:41 AM
SCI_P304 Guide to the major amendments in BS 5950_2001-1859421318.pdf
[-] The following 6 users Like bigone's post:6 users Like bigone's post
  • Andrew seah, Jackass, Dell_Brett, PinkPant, yanburak, milova
  Plastic Design to BS 5950 robertsas 2 2,535 12-17-2014, 03:38 AM
  SCI P080: Fire resistant design of steel structures - A handbook to BS 5950: Part 8 ir_71 2 2,130 05-14-2014, 05:33 AM
  SHS Design to BS 5950 Part 1 ir_71 2 2,215 03-31-2014, 08:52 PM
Last Post: yanburak
  SCI P326: Steelwork Design Guide to BS 5950-1 2000 6Ed username123 3 3,918 02-18-2014, 10:00 AM
Last Post: vinnunsam
  Steelwork Design Guide to BS 5950-1: 2000 jmpkumara 2 2,981 02-18-2014, 09:43 AM
  SCI P325: Introduction to Steelwork Design to BS 5950-1:2000 ir_71 1 1,584 11-15-2012, 03:34 PM
  Design of single-span steel portal frames to BS 5950 sheb101 2 2,777 01-28-2012, 09:19 PM
Last Post: joker™
