AnyReader 3.6 Build 834
Scratched, unreliable and damaged media reading! AnyReader is a data copy software for non-readable media: CD, DVD, LAN-Drives, flash memory, ZIP disks, floppy disks, etc. AnyReader effectively copies and saves corrupt data from any type of disks or erroneous connection where the standard copying methods fail. The program supports resumed downloads from the remote PC if the connection was broken while copying (especially useful for unreliable Wi-Fi networks).
AnyReader is great for copying files from scratched CD/DVD/Blu-ray or defective floppy/hard disks. Normally, when your computer is unable to copy files from a damaged disk it will abort and delete the part of the file it has copied. AnyReader will continue copying right to the end; any data that hasn't been recovered after several retries is replaced with blanks. This will allow you to truly copy every byte of information that can be read at all.
[Image: 64717722480325265401.jpg]
[Image: homepage.png]
[-] The following 10 users say Thank You to smk1981 for this post:
  • oanm2000, bhawk0, Clouseau, YaqubMughal, simanta, hcardenas, 3fan, niki102, chigozie, dquan373
Use Notepad to open CORE.NFO in Keygen folder to view iNSTALL/REGiSTER NOTES: Use the keymaker to register the application as follows:-
1) Install Program
2) Run program
3) Register by using Keygen to Generate, Copy Serial & Patch
[Image: 42910685785630445104.jpg]
[-] The following 4 users say Thank You to Learner for this post:
  • 3fan, niki102, chigozie, dquan373
Please Up load again, the link filesonic is dead.
Thanks before for you, uploader.
peace,
Jupe
[-] The following 2 users say Thank You to jupe01 for this post:
  • ranger, kvtasp
