Civil Engineering Association eBooks Geotechnical Engineering Tunneling Technical Manual for Design and Construction of Road Tunnels
 ELAHI1979
User ID: 13447
Threads: 54
Likes: 880 in 59 posts
Given Likes: 477
01-30-2011, 10:52 PM
[Image: 42873738030214895629.jpg]
The increased use of underground space for transportation systems and the increasing complexity and constraints of constructing and maintaining above ground transportation infrastructure have prompted the need to develop this technical manual. This FHWA manual is intended to be a single-source technical manual providing guidelines for planning, design, construction and rehabilitation of road tunnels, and encompasses various types of tunnels including mined and bored tunnels (Chapters 6-10), cut-and-cover tunnels (Chapter 5), immersed tunnels (Chapter 11), and jacked box tunnels (Chapter 12).
The scope of the manual is primarily limited to the civil elements of design and construction of road tunnels. FHWA intended to develop a separate manual to address in details the design and construction issues of the system elements of road tunnels including fire life safety, ventilation, lighting, drainage, finishes, etc. This manual therefore only provides limited guidance on the system elements when appropriate.
Accordingly, the manual is organized as presented below.
Chapter 1 is an introductory chapter and provides general overview of the planning process of a road tunnel project including alternative route study, tunnel type study, operation and financial planning, and risk analysis and management.
Chapter 2 provides the geometrical requirements and recommendations of new road tunnels including horizontal and vertical alignments and tunnel cross section requirements.
Chapter 3 covers the geotechnical investigative techniques and parameters required for planning, design and construction of road tunnels. In addition to subsurface investigations, this chapter also addresses in brief information study; survey; site reconnaissance, geologic mapping, instrumentation, and other investigations made during and after construction.
Chapter 4 discusses the common types of geotechnical reports required for planning, design and construction of road tunnels including: Geotechnical Data Report (GDR) which presents all the factual geotechnical data; Geotechnical Design Memorandum (GDM) which presents interpretations of the geotechnical data and other information used to develop the designs; and Geotechnical Baseline Report (GBR) which defines the baseline conditions on which contractors will base their bids upon.
Chapter 5 presents the construction methodology and excavation support systems for cut-and-cover road tunnels, describes the structural design in accordance with the AASHTO LRFD Bridge Design Specifications, and discusses various other design issues. A design example is included in Appendix C.
Chapters 6 through 10 present design recommendations and requirements for mined and bored road tunnels.
Chapters 6 and 7 present mined/bored tunneling issues in rock and soft ground, respectively. They present various excavation methods and temporary support elements and focus on the selection of temporary support of excavation and input for permanent lining design. Appendix D presents common types of rock and soft ground tunnel boring machines (TBM).
Chapter 8 addresses the investigation, design, construction and instrumentation concerns and issues for mining and boring in difficult ground conditions including: mixed face tunneling; high groundwater pressure and inflow; unstable ground such as running sands, sensitive clays, faults and shear zones, etc.; squeezing ground; swelling ground; and gassy ground.
Chapter 9 introduces the history, principles, and recent development of mined tunneling using Sequential Excavation Method (SEM), as commonly known as the New Austrian Tunneling Method (NATM). This chapter focuses on the analysis, design and construction issues for SEM tunneling.
Chapter 10 discusses permanent lining structural design and detailing for mined and bored tunnels based on LRFD methodology, and presents overall processes for design and construction of permanent tunnel lining. It encompasses various structural systems used for permanent linings including cast-in-place concrete lining, precast concrete segmental lining, steel line plate lining and shotcrete lining. A design example is presented in Appendix G.
Chapter 11 discusses immersed tunnel design and construction. It identifies various immersed tunnel types and their construction techniques. It also addresses the structural design approach and provides insights on the construction methodologies including fabrication, transportation, placement, joining and backfilling. It addresses the tunnel elements water tightness and the trench stability and foundation preparation requirements.
Chapter 12 presents jacked box tunneling, a unique tunneling method for constructing shallow rectangular road tunnels beneath critical facilities such as operating railways, major highways and airport runways without disruption of the services provided by these surface facilities or having to relocate them temporarily to accommodate open excavations for cut and cover construction.
Chapter 13 provides general procedure for seismic design and analysis of tunnel structures, which are based primarily on the ground deformation approach (as opposed to the inertial force approach); i.e., the structures should be designed to accommodate the deformations imposed by the ground.
Chapter 14 discusses tunnel construction engineering issues, i.e., the engineering that must go into a road tunnel project to make it constructible. This chapter examines various issues that need be engineered during the design process including project cost drivers; construction staging and sequencing; health and safety issues; muck transportation and disposal; and risk management and dispute resolution.
Chapter 15 presents the typical geotechnical and structural instrumentation for monitoring: 1), ground movement away from the tunnel; 2), building movement for structures within the zone of influence; 3), tunnel movement of the tunnel being constructed or adjacent tubes; 4), dynamic ground motion from drill & blast operation, and 5), groundwater movement due to changes in the water percolation pattern.
Lastly, Chapter 16 focuses on the identification, characterization and rehabilitation of structural defects in a tunnel system.
[-] The following 30 users Like ELAHI1979's post:30 users Like ELAHI1979's post
  • Dell_Brett, melkat, cigutierrezg, usman, avanchai, blaze, shaqee, zrilek, elitvdis, oanm2000, huy2009, Notter, DamaD, hrezaei, salahcivil, dbsimon29, Evandrojr, cristi, madkestas, Jackass, fer962933, utan, shadabg, lisine, gulilero, kowheng, bigone, tuanpecc1, habibi, sacem
09-04-2012, 12:52 PM
[-] The following 10 users Like shadabg's post:10 users Like shadabg's post
  • cace-01, gulilero, lednar_ved, malc, Jackass, oanm2000, neikrof, bigone, Dell_Brett, Andrew seah
 bigone
User ID: 4505
Threads: 92
Likes: 5,722 in 517 posts
Given Likes: 7145
11-21-2013, 10:45 AM
online Publication
Technical Manual for Design and Construction of Road Tunnels - Civil Elements
[-] The following 5 users Like bigone's post:5 users Like bigone's post
  • Dell_Brett, Evandrojr, oanm2000, Hengki, zrilek
  Design of pressurized Shafts and Tunnels Liners gianniorlati 1 3,326 01-17-2018, 10:12 AM
Last Post: scorpion07
  Design and Construction of Tunnels Ultra Zone 8 8,328 11-09-2017, 07:18 PM
  Structural Design Models for Tunnels gianniorlati 0 1,649 07-19-2015, 07:54 AM
Last Post: gianniorlati
  NCHRP S415 - Design Fires in Road Tunnels mahyarov 1 1,789 12-20-2014, 04:55 PM
  Seismic Design of Tunnels - A Simple State-of-the-Art Design Approach asim99 2 2,380 11-26-2012, 10:29 AM
Last Post: shadabg
  Design Manual for Road Tunnel abudabeeja 3 3,905 10-31-2011, 08:43 AM
Last Post: 3fan
