a few Matlab programs for finite element
3D Solid 20-Node Element Program
This program can analyze all types of 3D continous or solid body problems with all degree of freedom using Finite Element Method with choice 20-Node Isoparametric element under any kind of concentrated nodal loadings (Fx, Fy, Fz) and submit values of nodal displacements and element stresses as MATLAB output.
Finally, to test this program, different Examples are given which in these examples program outputs compared with the results from ABAQUS or ANSYS software. Similarity of results shows that this program works without any deficiencies as well as these two softwares.
[Image: 44738700948934858690.png]
4-Node Isoparametric Element Program
This program can analyze all types of plane stress and plane strain problems with all degree of freedom using Finite Element Method with choice 4-Node Isoparametric element under any kind of concentrated nodal loadings (Fx, Fy) and submit values of nodal displacements, element and nodal stresses as MATLAB output.
[Image: 75704338024692948079.png]
Constant Strain Triangle Element Program
This program is able to analyze all types of plane stress and plane strain problems with all degree of freedom using Finite Element Method (with choice “CST”-Constant Strain Triangle element) under any kind of concentrated nodal loadings (Fx, Fy) and submit values of nodal displacements, element stresses and strains and elements principal stress as MATLAB output.
to test the program we compare results of two examples with commercial programs.
[Image: 59237131329811798017.png]
2D Truss analyses using stiffness method
This program can analyze all types of 2D trusses with all degree of freedom using stiffness method (matrix analysis) under any kind of concentrated nodal loadings (Fx , Fy) and submit values of reactions, nodal displacements, axial forces and element stresses and strains as MATLAB output. to test the program we compare results of two examples with commercial programs.
[Image: 94901453581976584808.png]
2D Frame analyses using stiffness method
This program is able to analyze all types of 2D frames with all degree of freedom using stiffness method under any kind of concentrated nodal loadings (Fx, Fy, Mz) and submit values of supportive reactions, nodal displacements, element forces as MATLAB output.
Finally, to test this program, different examples are given which in these examples program outputs compared with the results from commercial softwares.
[Image: 97453619461890889075.png]
[-] The following 13 users say Thank You to lizard for this post:
  • jcbv, tarado, Dell_Brett, usman, NAUTILUS87, cace-01, jcoronellr, Clouseau, pm81, jf28, Nilupa, pram, rezart
a few Matlab programs for structural dynamics lizard 0 4,119 01-01-2011, 08:08 PM
Last Post: lizard
