Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Analysis: GoBeam
Analysis: GoBeam
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,128
Likes: 30,980 in 4,091 posts
Given Likes: 612
Points:282,462 EP
07-12-2009, 04:31 PM (This post was last modified: 08-04-2013, 04:40 PM by LiviuM.)
GoBeam
The file includes the original (shareware) version and a little bit changed version.
GoBeam
The easiest and most straight forward continuous beam analysis program available. Features concentrated and linear loads, support settlements, beam on elastic foundation, and influence lines analysis.
GoBeam - continuous beam analysis
The main asset of GoBeam is productivity. The simple and clear interface layout offers minimum time to enter beam parameters and to get complete analysis results, including graphs and tables. Despite visual simplicity GoBeam offers useful features not available in the majority of other beam programs.
Features:
Modeling
•up to 10 spans
•concentrated and linear loads
•Free or fixed ends of the beam
•Column supports (above or below)
•elastic supports
•In-span hinges (moment release)
•Variable beam stiffness within a span
•Sway frame option (for beams with columns)
Functionality
•static analysis
•beam on elastic foundation non-linear analysis (compression only elastic supports)
•support settlement analysis
•influence lines of section forces, support reactions and deflections
•SI and US customary units
•Multiple load cases
screenshots:
[Image: 33536900395945226874.jpg]
or
Link changed and alive.
[-] The following 57 users Like BennyP's post:57 users Like BennyP's post
  • oanm2000, oanm2000, simanta, simanta, aslam, aslam, Dell_Brett, Dell_Brett, JCMAS, JCMAS, l_namali, l_namali, lucky_b2me, lucky_b2me, zrilek, zrilek, pap2007, pap2007, parwez007, parwez007, isurya, isurya, Gabemzaman, Gabemzaman, tgbyhn1234, tgbyhn1234, cristi, cristi, vvvv, vvvv, ivanveliki, ivanveliki, tavos251184, tavos251184, rvcpkumara, rvcpkumara, bigone, bigone, pmist, falconado, super_engineer, yutt, pmav99, deanz_75, Petrit, priyoyo, hcardenas, bhawk0, hmwere, fretts08, ykhackhack, karthikeyans3d, maijuji, kchatza, mahyarov, mohcivil, mowafi3m
 jgarciafic
Peru
User ID: 3150
Threads: 50
Likes: 749 in 61 posts
Given Likes: 281
Points:4,302 EP
10-13-2009, 07:09 PM
(10-13-2009, 06:16 PM)super_engineer Wrote: Can You upload it again please
the link is dead!!!
Hi super_engineer
try this link mirror
good luck
[-] The following 7 users Like jgarciafic's post:7 users Like jgarciafic's post
  • timosi™, timosi™, zrilek, zrilek, super_engineer, ykhackhack, bashir999
 Bashem
User ID: 9195
Threads: 0
Likes: 20 in 1 posts
Given Likes: 0
Points:163 EP
11-22-2010, 10:48 PM (This post was last modified: 11-22-2010, 11:20 PM by usman.)
Here is the GoBeam 2010.1 modificated version without No time, Span and Loads limitations that the trial version have.
I'm using in excel XP without problems.
Moderator Note
Always use coded links (with white background CODE box), direct transparent links are not allowed
Please have a look at forum rules
[-] The following 20 users Like Bashem's post:20 users Like Bashem's post
  • usman, aema, malc, bhawk0, ilgar, ravisbassi, hmwere, josmmg, Quantumm, itcssaec, GioRoc, jorgeramos, isurya, kairel82, madzaz, hcardenas, chapi2009, hkfatfatduck, ykhackhack, bigone
Away  joker™
User ID: 10925
Threads: 92
Likes: 7,244 in 938 posts
Given Likes: 2423
Points:37,131 EP
08-19-2012, 05:08 PM
No limits to creativity
[-] The following 9 users Like joker™'s post:9 users Like joker™'s post
  • cace-01, Dell_Brett, malc, ykhackhack, araza023, dieuhuyen, caifan, jonny78, bigone
Likes: 12,064 in 1,232 posts
Points:63,655 EP
04-02-2013, 04:13 AM
GoBeam133
[Image: 61303550043370909768.jpg]
The easiest and most straight forward continuous beam analysis program available. Features static and moving loads, support settlements, non-linear analysys of beam on elastic foundation and influence lines analysis. It allows elastic and column support conditions, hinges and variable beam stiffness.
Updates: More flexible choices of selecting design units; hinge support allows to analyze the series of simple span beams; file format has changed to *.xlsb for full compatibility with Excel 2010
[-] The following 24 users Like pezhmankhan's post:24 users Like pezhmankhan's post
  • ykhackhack, Andrew seah, andersen3, malc, Dell_Brett, bigone, ting tsai huang, cace-01, gafi, lisine, kowheng, maijuji, oanm2000, red_pool61, albani, usman, smrutigandh.42, arshiakh, blaze, adams, ssi3k, Atlanta77, Petrit, motivat
 ykhackhack
United States
User ID: 36960
Threads: 81
Likes: 3,670 in 707 posts
Given Likes: 8693
Points:36,879 EP
05-08-2013, 08:07 PM
@hignacio43
[-] The following 5 users Like ykhackhack's post:5 users Like ykhackhack's post
  • malc, chenamoy, dinu69in, Nedhal, learner20
Points:63,655 EP
08-24-2013, 11:02 AM (This post was last modified: 08-24-2013, 11:35 AM by pezhmankhan.)
GoBeam134
[Image: 88642905696861573216.png]
[-] The following 12 users Like pezhmankhan's post:12 users Like pezhmankhan's post
  • Dell_Brett, hmwere, Petrit, oanm2000, Andrew seah, hatkam, ykhackhack, stosto6666, hignacio43, inge911, dinu69in, ting tsai huang
Points:63,655 EP
05-31-2014, 04:06 PM
GoBeam141
[Image: 53181022187980956724.png]
Changes:
A few important changes have been made: Spreadsheet is adjusted to run fast on Excel 2013, more flexible printing options provided, beam diagram displays elastic supports, generator of beam on elastic foundation is added.
[-] The following 18 users Like pezhmankhan's post:18 users Like pezhmankhan's post
  • Mohammad6299, Dell_Brett, malc, dizz, dinu69in, ykhackhack, oanm2000, tomtumx, trmpereira, asumi, Rodmo376, mohcivil, ibg0203, l_namali, Limpias72, adams, monter, cristi
 l_namali
User ID: 2969
Threads: 11
Likes: 498 in 47 posts
Given Likes: 130
Points:2,130 EP
08-25-2014, 11:58 PM
MIrror link from post 8 thanks to pezhmankhan
[-] The following 13 users Like l_namali's post:13 users Like l_namali's post
  • Albert, simanta, malc, Mohammad6299, Limpias72, oanm2000, mowafi3m, tooraj41, adams, learner20, icmrb7777, melekeen, spat
Points:63,655 EP
03-02-2015, 04:05 PM
GoBeam 143
[Image: 01953375549302644066.png]
[-] The following 14 users Like pezhmankhan's post:14 users Like pezhmankhan's post
  • blaze, dinu69in, bridgeengineer, oanm2000, usman, malc, zrilek, PinkPant, cace-01, Williams, knrsa, Dell_Brett, MOSS2000, rangarajan
Pages (2): 1 2 Next »
