Pressure Vessel Design Manual
Author: Dennis R. Moss | Size: 13.6 MB | Format: PDF | Publisher: Gulf Professional | Year: 2004 | pages: 499 |
ISBN: 0750677406
[Image: 02509405759316686648.jpg]
Designers of pressure vessels and related equipment frequently have design information scattered among numerous books, periodicals, journals, and old notes. Then, when faced with a particular problem, they spend hours researching its solution only to discover the execution may have been rather simple. This book can eliminate those hours of research by providing a step-by-step approach to the problems most frequently encountered in the design of pressure vessels. This book makes no claim to originality other than that of format. The material is organized in the most concise and functionally useful manner. Whenever possible, credit has been given to the original sources. Although every effort has been made to obtain the most accurate data and solutions,it is the nature of engineering that certain simplifying assumptions be made. Solutions achieved should be viewed in this light, and where judgments are required, they should be made with due consideration. Many experienced designers will have already performed many of the calculations outlined in this book, but will find the approach slightly different. All procedures have been developed and proven, using actual design problems. The procedures are easily repeatable to ensure consistency of execution. They also can be modified to incorporate changes in codes, standards, contracts, or local requirements. Everything require for the solution of an individual problem is contained in the procedure. This book may be used directly to solve problems, as a guideline, as a logical approach to problems, or as a check to alternative design methods. If more detailed solutions are required, the approach shown can be amplified where required. The user of this book should be advised that any code formulas or references should always be checked against the latest editions of codes, ie., ASME Section VIII, Division 1, Uniform Building Code, arid ASCE 7-95. These codes are continually updated and revised to incorporate the latest available data.
[-] The following 19 users say Thank You to SR71 for this post:
  • kowheng, Dell_Brett, blaze, pedzaquino, malc, jcoronellr, toa011, zrilek, ilgar, usman, we_mbm, cristi, sasan7351, joamirose, Nilupa, Umer.Aleem, jcbv, nuttapolk, TAFATNEB
Bookmarked PDF|RAR 14.36|9.29 MB
RAR password: KCivilEA
[-] The following 11 users say Thank You to kowheng for this post:
  • Jackass, Dell_Brett, jcbv, dovsky, slowet, nuttapolk, knrsa, hignacio43, cowboy, draluka, harsono
Pressure Vessel Design Manual, 3rd Edition
Author: Dennis R. Moss, Michael M. Basic | Size: 13.6 MB | Format: PDF | Quality: Scanner | Publisher: Gulf Professional Publishing | Year: January 1, 2004 | pages: 499 | ISBN: 0750677406, ISBN-13: 978-0750677400
[Image: 72356586616097130380.jpg]
Picking up where the success of the previous editions left off, this book is an accumulation of design procedures, methods, techniques, formulations, and data for use in the design of pressure vessels, their respective parts and equipment. It's written specifically for designers and engineers involved in designing and specifying or manufacturing of pressure vessels. The book also has broader applications to chemical, civil and petroleum engineers who construct, install or operate process facilities, and would be a valuable aid to those who inspect the manufacturing of pressure vessels or review designs.
The format of this book continues to differ from most technical ones, as there are many handy visual aids throughout the text. It is not just a reference book, but a practical guideline, that aids designers and engineers to solve practically every design problem that an engineer might encounter with pressure vessels. As an easy-to-use reference, the book provides the user with a logical step by step approach to the design of ASME (American Society of Mechanical Engineers) Code vessels, such as the method for determining the Minimum Design Metal Temperature (an ASME requirement for all pressure vessels).
[-] The following 15 users say Thank You to lisine for this post:
  • ykhackhack, slowet, 3fan, duazo2009, jcbv, cace-01, oanm2000, ingenierobou, malc, kowheng, arceon, Dell_Brett, zrilek, smrutigandh.42, jacky899
Direct Links:Wink
Mirror :
[-] The following 5 users say Thank You to shadabg for this post:
  • oanm2000, seriousboy, Jackass, Hengki, nickycruz
Author: Dennis R. Moss | Size: 14.2 MB | Format: PDF | Quality: Unspecified | Year: 2004 | pages: 499
[-] The following 8 users say Thank You to TAFATNEB for this post:
  • ting tsai huang, Hengki, eliseo.as, bridgeengineer, PinkPant, Dell_Brett, dinu69in, Aviator
Pressure Vessel Handbook shadabg 0 1,338 09-15-2012, 11:10 AM
Last Post: shadabg
