Concrete: Concrete Short Column Analysis and Design
ShortCol
Calculates bending moment/axial force interaction diagram for rectangular or circular reinforced concrete column with typical or irregular rebar layout. Now calculates crack width under working stresses. Confirms ACI 318, AASHTO and AS3600 design codes.
ShortCol - investigation of reinforced concrete column section
ShortCol computes ultimate strength of reinforced concrete column subjected to combined axial force and bending moment. Ultimate strength is found from strain compatibility analysis assuming equivalent rectangular concrete stress distribution. In addition, ShortCol calculates transformed properties of fully cracked reinforced concrete section at ultimate limit state and calculates crack width at service limit states.
Another features:
•Shortcol analyses rectangular or circular shape concrete sections
•Rebar wizard quickly generates various typical and irregular bar layouts
•Crack width is calculated in accordance with ACI/AASHTO, British Standards, Eurocode 2 and AS3600
•Column design conforms ACI 318, AASHTO, AS3600 codes
•SI and US units
ShortCol limitations:
•Does not consider column slenderness and second order effects
•Uses only unconfined concrete properties
•Accepts only bonded to concrete reiforcing steel
The file includes the original (shareware) version and a little bit changed version.
screenshots:
[Image: shortr.th.jpg]
Links changed and alive.
[-] The following 21 users say Thank You to BennyP for this post:
  • Dell_Brett, Dell_Brett, kowheng, kowheng, ruaumoko, ruaumoko, paulocs, paulocs, cristi, cristi, rendel_©, rendel_©, Nedian, Nedian, Ultra Zone, rkce, rezart, Quantumm, robertsas, SCREAM7890, K.Lee
[Image: 88666899229157589379.jpg]
Mirror
430KB XLS
[-] The following 11 users say Thank You to usman for this post:
  • Dell_Brett, ISTRAKTURA, kowheng, rezart, Quantumm, robertsas, duyhiep83, malc, zainseiya, dinu69in, SCREAM7890
New links
[-] The following 15 users say Thank You to scorpion07 for this post:
  • versiondemo, mgdario, Albert, Dell_Brett, rami1976, Jackass, blaze, PinkPant, Andrew seah, oanm2000, karthikeyans3d, odiclas, K.Lee, rendel_©, Umer.Aleem
Spread Footing Analysis and Concrete Pedestal Design usman 1 5,359 06-29-2017, 04:41 PM
Last Post: ALMF
Concrete: Spreadsheets for Concrete Design to BS 8110 and EC2 rohailiyaz 4 9,495 04-12-2014, 07:52 PM
Last Post: darebert1000
Concrete: Rectangular Columns with Uniaxial Bending Analysis and Design by JEC robertsas 4 4,409 04-03-2014, 02:57 PM
Last Post: arshiakh
Concrete Short Column Analysis and Design - EC BennyP 2 5,391 08-24-2013, 12:23 PM
Last Post: pezhmankhan
Concrete: Concrete Design Spreadsheets RedHorse 3 8,300 04-21-2013, 05:22 AM
